Oscillating Boogie
  • Oscillating Boogie
    Hmm, I have a Mesa Boogie Rectoverb which had a board short that I fixed a few months ago that has a strange oscillation at different volume levels.
    It happens on both channels, tone controls have no effect, only at certain combinations of gain, volume and master volume settings.
    Any ideas before I rip into it?
    Alright let me clarify:
    If I whack on the guitar neck while fiddling the master output volume the amp will start motorboating-
    A low frequency oscillation that is all over the place, on the power supply being fed to all the tubes.
    I probed the phase inverter inputs and it went away, but not all the time.
    I'll start by check for a loose joint and possibly intermittant pot.
      Seems the 2nd half of V4 which is the effects return stage is where the problem is.
      I lowered the gain of that stage after troubleshooting the effects return circuit and the problem went away.
      Weird stuff.
