Last silly question
Scott,
The wiring hookup you depict will work fine
Some other relevant information to keep in mind is:
* The switch you are using is a single Pole Single Throw unit. (SPST)
* It is is not polarized so it will also work if you reverse the hookup of the brown and black wires. The "ON/OFF" label is just provided for convenience and optional use.
* One thing to plan for is the physical orientation of the switch when you mount it on your panel. That is, decide if you want the switch to be ON when the toggle handle is flipped up or down or even to one side. This depends on the function you are controlling with the switch. For a power switch most people would choose it to be ON when the toggle is up of course.
Cheers,
Tom
Originally posted by Jarvini View PostI think that's what confused me? The switch seems to have slightly less resistance moving from on to off so I thought it would be better that way round
You should measure essentially zero resistance in one position and essentially infinite resistance in the other position of the switch handle.
For any given position of the handle the resistance reading between the terminals should not change when you reverse the meter lead connections to the switch terminals
Originally posted by Tom Phillips View Post... For a power switch most people would choose it to be ON when the toggle is up of course. ...
Originally posted by Malcolm Irving View PostThat's the convention in the USA, but in UK the convention is the other way - down for on. Doesn't really mater - we are used to Fender amps etc. - just thought I'd mention it.
[ATTACH=CONFIG]47185[/ATTACH]
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Yep. After I posted I thought that might come up. Especially for a chassis that is used both in combo and head amps with just a front panel change. Same reason that some amps have the guitar inputs on the left vs. the right side.
Standby discussions can get complicated.
"I was on/in standby"
"I turned the standby off"
etc.
Maybe instead of labels like "Play" & "Standby" and "On" & "Off" we should use
"Boring" & "Awesome!" and "Happy Neighbors" & "Cops Are Here!"
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
[ATTACH=CONFIG]47185[/ATTACH]My band:- http://www.youtube.com/user/RedwingBand
I don't know about "copy", but I have never seen an amp where the power switch flips one way and the standby switch flips the other to operate. Whether it is facing up or down, it is always both in the ON position to play.
In the USA, we generally think UP for on. The wall switch for my ceiling light goes up for on.Education is what you're left with after you have forgotten what you have learned.
