I recently had an amp (Pignose G40V) in here for some work. The owner had recently installed some new preamp tubes, the reissue Tung Sol 12AX7's, a week or two prior to the problem developing. The symptoms he had was a progressive loss of power / volume. He only uses the amp on Sunday's at church, so the new tubes didn't have a lot of time on them, just a couple of hours at most. I found very low output on the cathode follower out to the tone stack, the signal was very weak. I swapped that tube out and the amp was back up to full output. I called him to let him know what I found. He had bought the tubes somewhere with no warranty. So he ordered another Tung Sol 12AX7 from a different supplier and had it sent to me. I installed it, checked it out, everything was tits. So I let him know it was ready to go and I buttoned it up and set it aside. When he came to pick it up we plugged it in and gave it a try, and damn but the same exact problem was there again. This time the amp had less than a couple of hours of use before the tube failed.
Besides a very weak AC voltage at the cathode follower (with a 1k sine wave at the input) the DC voltage was very low. The schematic calls for 162vdc at the CF, we had something around 60 IIRC. I grabbed a spare tube out of a drawer and stuck in place of the Tung Sol and the DC voltage came right up to about 166 and the output was right back up to full. He had also installed a Tung Sol in the V1 position, I swapped it from the V1 position into the V2 CF position and stuck the spare tube into V1, and the voltage and output dropped right back down again with this tube. I pulled another spare tube out of the drawer and swapped out the Tung Sol in V2 and everything was right back to normal again. We left the spare tubes in V1 & V2 and he tossed the Tung Sol's into my waste basket before he left.
I have a hard time believing three different tubes from two different suppliers, would have the same condition. But there is no denying that the Tong Sol's had very low output at the cathode follower. They seemed to work fine to begin with but quickly the performance went away.
I know the cathode to filament voltage at a CF can approach the limit for a 12AX7, but they seem to work fine in plenty of amps with a CF in the preamp. Any ideas what's going on with these Tung Sol's? I did pull them out of the waste basket after he was gone, and I'd like to do some other testing on them to verify they are sub par. Any ideas?
