Hi everybody, I've finally found a solution for the hum/buzz problem. I installed a small sub-PCB which converts the AC heater voltage to DC and feeds it to the three preamp-tubes. The hum is completely gone now. The power tubes are still heated via AC.
DC is produced by rectifying the 6.3VAC with four 1N4007 Diodes and smoothing the voltage with four 4700uF caps two of which are referenced to Ground. Works like a charm :-) I don't know why my amp was humming more than others though. Maybe any parts around V2 got microphonic, e.g. that capacitor in the smaller Epoxy-block. However, now it is solved.
But I have another issue still occurring that I had encountered before: With the Volume-pot fully ccw there's still some significant amount of signal passing through the amp and out of the speakers. It is very muddy and lacks a lot of treble, but still it's actually pretty loud. I tried swapping the pot for a new one but this didn't help. Also I tied the grid of V1b to Ground and STILL there is signal coming out of the speakers. That's really strange. Could the signal be passing through to the second tube using another way?
When the anode decoupling cap of V1b is tied to Ground there is no signal passing anymore and the hiss that the amp has is gone as well. So it seems that the signal is somehow transferred from V1a to V1b. I tried different tubes in that position so it shouldn't be a bad tube.
Any ideas regarding these issues would be really great. What else can I test to clarify what is causing the issue?
Thanks heaps!
PS: I don't understand why this post didn't make it to the end of the thread, sorry for this.
Thanks heaps!
