Strange 'Lunchbox' amplifier
  • Strange 'Lunchbox' amplifier
    Anyone ever see one of these puppies before?
    Output ic is a TDA2030.
    It has two 9V battery holders in series.
    No clean signal at all.
    It's distortion or more distortion.
    Sounds good for what it is.
    Are you sure its not home-made? It seems to have a "cigar box guitar" aesthetic. Is that speaker grill cannibalized from a vegetable steamer????
    EDIT: Does it have one of these ~$1.25 Chinese amplifier boards inside?
    https://www.ebay.com/sch/i.html?_fro...a2030&LH_BIN=1
    -rb
    DON'T FEED THE TROLLS!
      It does not appear to be a one off, home made amp.
      The pocket for the PCB is milled out.
      On off switch, LED indicator, polarity diode on the PCB for the battery + voltage, two 9volt battery compartments.
      The covering is made to have international hotel stickers all over it, like a suitcase.
      The only markings on it are on the snap buttons.
      "MCD"
      "More Core Division".
        Well, I got the word from the owner.
        Yes, it is a one off.
        The amplifier guts came from another battery powered amp.
        And, the grill is indeed from a food processor.
          I think it is fantastic.
            For everyone's sake, I sure hope that food processor was already broken....
              Food processor blade helps the tone cut through the mix.
                Darn. Why didn't I think of that one?
                Well played, sir.
                -rb
                  Reminded me of this old chestnut.
                  I always kind of wanted one (they did guitar and ukelele versions) but unfortunately they had a very short lifespan. In both availability and physical reliability.
                    I suggested a speaker out jack as it has a decent TDA2030 IC for an output.
                    I used a jack that cuts out the existing speaker when a cab is loaded in.
                    With 24Vdc into the dc jack (that I added) it sounds pretty gnarly into a Marshall 4 x 10 stack.
                      I thought it was the built-in rotary speaker, so you don't have to haul the Leslie around.
                      Justin
                        2 x 9V batteries supply are a brickwall, but an external power jack and a real supply should make it work properly.
                          Yup.
                          Added an external dc jack.
