Page 2 of 2 FirstFirst 12
Results 36 to 58 of 58
Thread: CEM3381 Dual VCA
  1. #36
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,418
    Received: 435/1
    I checked my inventory sheet, only Curtis chips I stock are:
    CEM3340, 3360, 3372, and 3394.
    But the thought occurs to me, didn't you say you ONLY have the amp module and will be using it alone - not with the rest of the keyboard?
    If so, then why have the remote voltage control over volume in the first place? Replace the VAC with a pot.
  2. #37
    Old Timer nosaj's Avatar
    Sep 2011
    Pace, FL
    1,767
    Received: 172/20
    Given: 24/5
    No as soon as it's working I want to put it back in the piano. I only just have the power amp right now.
    Jason
  3. #38
    Sep 2011
    Pace, FL
    1,767
    Received: 172/20
    Given: 24/5
    Ok, hereīs the FET VCA:
    Attachment 49131
    We ditch the dead PA381, we use the FET as a voltage controlled attenuator .
    Attenuator is a series resistor (in principle we leave the original 39K) and a FET to ground, working as a variable resistor.
    Its value will go from around 100 ohm (which is not perfect Zero but in any case *a lot* of attenuation, should be more than enough) to infinite, so no attenuation, when we vary Gate voltage from 0V to +5V.
    NOTE: since available control voltage is positive, we need a P channel Fet, not the more common N channel type.
    Most Fets dissappeared from the market, but J176 is still available.
    We pull the dead PA381 but use its PCB holes as reference and we can mount a couple "new component" legs on them; extra component legs should be tack soldered to needed pads, if already occupied.
    I guess you will have to add the two J176 from below, the copper side, should not be a problem.
    If too close to chassis, then you will have to solder it from above, do whatīs most comfortable to you.
    This will vary volume as expected, maybe not as smoothly, but acceptable.
    If level is too high or too low, gain can be adjusted; with my values it "should" be about unity gain with +5V, which I guess was the original gain, but if not, itīs adjustable, up or down, varying a couple resistors.
    Ok, get the P Fets and try it.
    Good luck.
    Why would I need to put jfets on opposite side of board. i was thinking about using a 8pin DIP socket to just plug the jfets into. That should be fine I would think, no?
    nosaj
  4. #39
    Dec 2009
    Devon, UK
    2,814
    Received: 108/0
    Given: 66/0
    Kinda missed this thread. I'm 95% sure I have some PA381's if you still want one...
  5. #40
    30,418
    Received: 435/1
    There y'go^^^
    It is the circuit that matters, put the parts where you like.
  6. #41
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,290
    Received: 347/5
    Given: 356/5
    Quote Originally Posted by nosaj View Post
    nosaj
    It was not an "order" but a "suggestion", accompanied by "do whatīs most comfortable to you."
    That said:
    1) I donīt trust IC sockets and even less here, they wonīt firmly grab the thin Fet legs.
    2) in any case some Fet connections are NOT to IC holes/pads anyway.
    3) in holes 3 and 5 youīll need to insert BOTH a resistor leg and a Fet leg .... hard to solve with an IC socket.
    4) top Fet Source goes to R77 ground pad (on bottom) or scratched and tinned top leg ... your choice.
    5) bottom Fet Source goes to R75 ground pad (on bottom) or scratched and tinned top leg ... your choice.
    6) thereīs more than one way to skin a cat ... I suggest a couple just in case
    7) just read nickbīs post ... if an original is available, by all means use it
  7. #42
    Sep 2011
    Pace, FL
    1,767
    Received: 172/20
    Given: 24/5
    i just didn't understand quite why 3 explained it for me.
    Just waiting for nickb response, jfets are on the way.Can't hurt to have parts to instantly try something instead of waiting in the future.
    Thanks all.
    nosaj
  8. #43
    Sep 2011
    Pace, FL
    1,767
    Received: 172/20
    Given: 24/5
    Quote Originally Posted by nickb View Post
    That's a definite PM sent with my info.
    Thanks,
    Jason
  9. #44
    Dec 2009
    Devon, UK
    2,814
    Received: 108/0
    Given: 66/0
    Thanks,
    Jason
    ..and responded to. I'll have to venture into the dustiest & darkest places of my Old Parts Emporium.
  10. #45
    Oct 2007
    10,290
    Received: 347/5
    Given: 356/5
    Thanks all.
    nosaj
    P-Fets are an ignored and very useful tool, great advantage being they can be used as switches or attenuators being contolled by **positive** voltages, which are more easily available (specially on pedals ) .
    Look at Phasers; in order to use more common (specially way back then) N Fets as variable phase shifters, they are *forced* to "elevate" Sources so Gates can be made "negative" (actually "less positive" ) for control.
    P Fets provide elegant simple solutions, they can be straight driven by, say, Logic voltages, output of microprocessors, etc. , which can provide *any* voltage you imagine ..... between 0 and +5V that is
    I always have at least a dozen handy, saved my bacon many times.
  11. #46
    Oct 2007
    10,290
    Received: 347/5
    Given: 356/5
    They-were-somewhere-around-here
  12. #47
    Sep 2011
    Pace, FL
    1,767
    Received: 172/20
    Given: 24/5
    FETS are here will wire them up in the morning. Still waiting on response from Nickb on payment. Never had to figure foreign exchanges before.
    nosaj
  13. #48
    Oct 2007
    10,290
    Received: 347/5
    Given: 356/5
    nosaj
    https://www.x-rates.com/calculator/?...o=USD&amount=1
    Rather than exchange rate, problem is how to wire them to a physical person.
    Shops or EBay sellers already have setup some system, maybe Paypal or similar.
    The lowest/simplest system, quite crude and which has some minimum fees no matter what you transfer, is Western Union or Moneygram.
    Designed for and most used by undocumented aliens (no kidding) who work "here" and want to send money to Mom or Family "there" , works like this:
    sender deposits money, plus , say, 2% to 5% (so far, "nothing", unless you are transfering, say, U$10000) plus a fixed fee, of, say, 5 or 6 U$, which is nothing on a large amount, a lot if you have to transfer $3.
    You mail receiver what office address you sent $ to, how much, who sent it (may be a nickname), all this as a crude security system, and sometimes a serial number or password, all of which will be asked by cashier at the receiving end.
    Actually simpler than it sounds, and works very well for small to mid amounts, say less than $100.
    We are "Paradise Country" compared to all around us, so we are chock full of undocumented immigrants from all of Latin America (even Colombians and Venezuelans who are actually quite far away) , refugee Africans (Nigerians, Camerunese), Syrians, Koreans, Chinese, Ukrainians, the works, all use this system so itīs well oiled and works flawlessly.
    Even for Dominican prostitutes .... no kidding.
    Being US created and run Services, they should work well with UK.
  14. #49
    Dec 2009
    Devon, UK
    2,814
    Received: 108/0
    Given: 66/0
    Found them!!!
    Jason: I'll send you a Paypal doohickey. That will take care of exchange rate calcs.
  15. #50
    Sep 2011
    Pace, FL
    1,767
    Received: 172/20
    Given: 24/5
    Juan, part is one the way from nickb.
    But on another how critical in your VCA replacement is the 39k resistors? I have 33k then 47k's.
    nosaj
  16. #51
    Oct 2007
    10,290
    Received: 347/5
    Given: 356/5
    Oh, not critical at all, any will do.
    I suggested 39k simply because there was another same value already there.
  17. #52
    Sep 2011
    Pace, FL
    1,767
    Received: 172/20
    Given: 24/5
    This is the jfet setup you suggested. The replacement chip is on the way from nickb. While waiting I'm considering breadboarding up the pa381 I do have.
    I wired them in used 33k instead of 39k. Still not picking up signal on IC11 pin7. If I remove jp1 I get signal on the middle pin. Now If I move the scope into the millivolt I can see a litttle signal there. But it is fuzzy looking. I decided to check voltage at jp1 no dc on pins 1 and 2 on pin3 getting 4mvDC. To me it looks like IC12 might be the only place to pick that up at.
    Any suggestions or am I wasting time again?
    Thanks,
    nosaj
  18. #53
    Oct 2007
    10,290
    Received: 347/5
    Given: 356/5
    Thanks,
    nosaj
    Where? I see no image in this post.
    EDIT: SUPPOSING you are talking abot the edited schematic where I showed the P Fets replacing the PA381:
    1) are you injecting signal into point(2) ? .... Y/N
    Say, 100mV 1kHz.
    2) If you scope there, do you see 100mV 1kHz there? ..... Y/N
    3) are you applying +5V into point (3)? .... Y/N
    4) scope the right side of R55 , any leg of C75 , bottom J175 Drain leg, left leg of added "39K" (33k?, 47k? .... same thing) ... you should have signal, about 50mV, on ALL of those points ... do you? .... Y/N
    IF signal present on some but not all ... where?
    5) measure DC at Gate legs on both P Fets ... do you have +5V there? ... if not, what DCV you measure there?
    6) test the FET VCA effect: varying voltage at point (3) from 0 to +5V ... does audio voltage vary on points mentioned in question 4) ?
    Thanks.
    EDIT 2: notice I am not even *asking* about what happens on IC11 (yet) , not even at JP2 (same thing).
  19. #54
    Sep 2011
    Pace, FL
    1,767
    Received: 172/20
    Given: 24/5
    Say, 100mV 1kHz.
    Yes
    2) If you scope there, do you see 100mV 1kHz there? ..... Yes
    3) are you applying +5V into point (3)? .... Yes
    4) scope the right side of R55 , any leg of C75 , bottom J175 Drain leg, left leg of added "39K" (33k?, 47k? .... same thing) ... you should have signal, about 50mV, on ALL of those points ... do you? .... Yes
    5) measure DC at Gate legs on both P Fets ... do you have +5V there? ...yes
    6) test the FET VCA effect: varying voltage at point (3) from 0 to +5V ... does audio voltage vary on points mentioned in question 4) ? Yes
    Thanks.
    So your Jfet replacement works just like you want Good signal at IC11pin7. It all looks good inputting at R55. So I move injection point back to CN10 pin3 and 5 jumpered. And IC11pin7 goes back to almost no signal. So between cn10 pin5 and r55 something is killing signal.
    Thanks for your help Juan.
    nosaj
    1 Not allowed! Not allowed!
  20. #55
    Sep 2011
    Pace, FL
    1,767
    Received: 172/20
    Given: 24/5
    Say, 100mV 1kHz.
    Yes
    Thanks.
    nosaj
  21. #56
    Oct 2007
    10,290
    Received: 347/5
    Given: 356/5
    Cool.
    So FET VCA IS working as intended.
    Ok, youīll have to trace that, but now itīs standard troubleshooting: inject signal at connector, **check that itīs still there** (connector or following track might be shorted to ground) and scope along the path.
    You may have a cracked open track anywhere along the path; most suspect points are near Cn10 itself or R55 (less likely but not impossible).
    Connectors are often yanked and a crack develops between one of its pads and tracks leading away from them, or one might have developed where R55 pad receives a track.
    You may scratch solder mask about halfway the track joining both and check.
  22. #57
    Sep 2011
    Pace, FL
    1,767
    Received: 172/20
    Given: 24/5
    Cool.
    Found it. The junction between r55 to r56,r57 was not there. Fixed the track and with .3v 1kz in at cn10 pins 2 and 5 I get 6.5v out at CN4 left and right channels. Which sounds good to me as this is just the power amp and not the preamp.
    Juan Thanks so much for sticking with me. When the pa381 gets here I guess I will just put it in my parts bin. Your clever solution rocks and I hope to implement some of the j176's in other projects.
    nosajClick image for larger version.
  23. #58
    Sep 2011
    Pace, FL
    1,767
    Received: 172/20
    Given: 24/5
    Returned it to it's rightful place in the piano all is working good on the amplifier now. No display at all on So I gotta look at that. But it's playing.
    Thanks,
    nosaj
    Doe anyone know how to test a cold cathode florescent display? Here is the datasheethttp://www.beyondinfinite.com/lcd/Li...i/SP14Q001.pdf
    The dc/ac converter had q1 q2 c2 and sp1(fuse ) were burnt up. I replaced them but no display yet.
  1. VCA noise
    By Mick Bailey in forum Music Electronics
    Last Post: 07-05-2016, 08:14 AM
  2. Old Dual-Pro type dual OT
    By EFK in forum Theory & Design
    Last Post: 11-28-2012, 02:14 PM
  3. 18W Footswitchable Dual Channel Dual Cascade Head Build
    By ForcedFire in forum Build Your Amp
    Last Post: 12-02-2010, 07:06 PM
  4. Roland Juno-106 VCO/VCA/VCF issues.....
    By jrfrond in forum Music Electronics
    Last Post: 05-28-2010, 04:05 PM
  5. Replies: 0
    Last Post: 06-25-2007, 11:19 PM
