Hi Folks.
Quick question to fill the nooks and crannies of my knowledge on power filtering and voltage ratings.
Two caps rated at 500 Volts in series can accept 1000 Volts, correct? Then Two caps in parallel will still only be able to accept a 500 Volt max. Also correct?
I find that in the info widely available on the internet, voltage isn't as popular a topic when talking parallel as they are when talking series. So honestly I am a bit uncertain.
And what are people - or how - are they using these types of caps... let's say your average F&T 500 volt cap. What max voltage should be pumped into one? There is so much depending on what the wall voltage is in any particular moment to say that a power tranny that dumps 480 Volts DC from the rectifier would be fine... because one tranny that puts out 480 Volts today can be 490 tomorrow, or even more.
Is there a "rule" in such case?
Thank you!
Thank you!
