Results 1 to 10 of 10
Thread: Sidewinder pickup design ?
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,067
    Received: 8/0
    Given: 5/0
    Compared to a single pole design like a P-90, & trying to recreate the true tone of a p-90 based on 10k turns p-90 , going with a Sidewinder dual coil hum free design we are kind of fighting with too much treble & at the same time way less output & as an example an 8k p-90 will produce more output than a 9k sidewinder pickup .please discuss your findings ?
    My latest attempt has been to increase the bass ,& i need to increase the magnet strength to help with the output maybe A5/A8 .
    Jun 2015
    223
    Received: 1/0
    Quote Originally Posted by copperheadroads View Post
    I'd be interested in seeing pictures of your pickup.
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,152
    Received: 96/21
    Given: 102/9
    On bass sidewinders, trying to keep them bright.
    They needed thin small blades for brightness, and highs.
    So maybe for guitar, bigger thicker blades.
    To get the output up on the bass pickups, the magnets inside the bobbins were stronger than outside magnets.
    Maybe you can put the magnets inside the bobbins.
    GL,
    T
    “When you find yourself in a hole, quit digging.” WILL ROGERS
    Keep Rockin! B_T
    Jun 2009
    2,067
    Received: 8/0
    Given: 5/0
    Well this design I'm using blade style bobbins & bar magnets on there side butting up against the keeper bar & pole screws through the keeper.
    Jun 2015
    223
    Received: 1/0
    Maybe check to see if the magnets are fully charged and are oriented N-S S-N. I'm picturing the AlNiCo bars are the cores of the two coils, that might yield a lower inductance than you'd expect for 8k-9k pickup with slugs or screws in their core.
    Supporting Member
    PDX
    3,215
    Received: 4/0
    Given: 2/0
    Q-Tuners used pole screws but Erno juiced them up with fairly substantial neodymium bars that don't quite touch the screws.
    Member Alberto's Avatar
    May 2015
    Italy
    82
    Received: 2/0
    Given: 2/0
    I'm using your same design (blade style bobbins & A5 bar magnets on there side against the keeper bar & pole screws through the keeper) with 8,5k turns per bobbin. It doesn't sound the same as a "real" p-90, but I like it, sort of a mix between a P90 and a strat. Fralin uses neodymium bar magnets to get the basses out of them, but they are too dark for my tastes. Maybe experimenting with neodymium bar magnets and different turns per bobbin could get you near the desired results.
    Jun 2009
    2,067
    Received: 8/0
    Given: 5/0
    Quote Originally Posted by Alberto View Post
    Yes this is what i've done in the past have overwound coils to help darken the tone & also i will try to source some neodymium in bar form to help give the pickup more wotput .
    Also maybe ditching blade bobbins & making shorter/fatter bobbins out of forbon maybe a something to try .
    Jun 2009
    2,067
    Received: 8/0
    Given: 5/0
    Quote Originally Posted by big_teee View Post
    GL,
    T
    I guess if i used the mudbucker design where the steel blade goes through the coils & use a strong magnet on the ends i may help .
    Senior Member Chris Turner's Avatar
    Nov 2009
    Tucson, AZ
    240
    I made these a little while back, and they worked out great for me.
    Stainless steel blade, with neo rod magnets. Plenty of output, and still retains lots of highs and bass response is tight.
    Attachment 49038
    Attachment 49039
ID:	49036   Click image for larger version.
  1. Pickup Winder Sidewinder
    By JCrab in forum Flea Market
    Last Post: 10-29-2012, 02:55 AM
  2. Pickup design for stealth esquire pickup suggestions needed
    By gdmart in forum Beginner/ Hobbyist
    Last Post: 09-03-2012, 08:10 PM
  3. Replies: 2
    Last Post: 08-27-2012, 11:50 PM
  4. Replies: 30
    Last Post: 12-04-2011, 01:59 AM
  5. Strat pickup design I'd never seen before
    By Euthymia in forum Pickup Makers
    Last Post: 09-11-2009, 11:50 AM
