Results 1 to 11 of 11
Thread: Can somebody review this diagram?
    Junior Member
    Mar 2016
    Brooklyn, NY
    9
    Hey, fellas.
    I got a custom wiring diagram from guitar electronics guys and last night after putting everything together, it's not working out. The bridge position seems to be shorted out and all three pickups are engaged in the 5th position. Can somebody take a look at it?
    Just to clarify this is for a Robbie Robertson style strat, so the middle and bridge are next to each other to form a humbucker.
    -I'm sorry, I've realized that this is in a wrong topic. Not sure if I would be able to move this thread over to guitar tech.
    Dec 2008
    Wernersville, PA
    12,278
    Received: 58/0
    Given: 21/0
    It sounds as if your issue is with the switch wiring.
    Drawings are nice to have but you can't beat an ohm meter when it comes to figuring out what the switch is doing.
    Dec 2013
    206
    Received: 25/0
    Given: 7/0
    I'm familiar with a 4 pole/5 way switch with the commons at each end, is that what you have?
    Junior Member
    Mar 2016
    Brooklyn, NY
    9
    Quote Originally Posted by Jazz P Bass View Post
    Yeah, I've spent the whole day with my multimeter troubleshooting this, I have a feeling it'll be a few more days before I get it working.
    Quote Originally Posted by ric View Post
    Yes, that's the one
    Dec 2013
    206
    Received: 25/0
    Given: 7/0
    Flaw in the late night wiring. Post deleted.
    Ok, here goes
    Pickup hots-nk=a mid=b br=c
    Pickup grounds- mid=d
    Ground nk and br grounds
    Tie nk tone to nk hot
    Tie mid/br tone to br hot
    v=vol g=ground 0=no connection
    Switch tabs-
    left side top to bottom-
    v,c,b,b,a,a,0,d,0,v,0,c
    right side top to bottom-
    v,0,0,c,b,0,0,0,g,g,0,d
    This oughta work. Let us know how it turns out. Sorry for earlier incorrect response.
    Dec 2013
    206
    Received: 25/0
    Given: 7/0
    Bklynghost please note correction to my earlier post.
    Junior Member
    Mar 2016
    Brooklyn, NY
    9
    Thank you so much, I finally got to sit down and wire this up and it worked perfectly. I can't believe you were able to come up with this on your phone, super switches are my kryptonite. Is there some secret to mastering the damn thing?
    Thanks again, Ric you are a lifesaver.
    Dec 2013
    206
    Received: 25/0
    Given: 7/0
    Quote Originally Posted by Bklynghost View Post
    I'm glad it worked out. If there was only one strat switch in the world I'd want it to be that one.
    I draw my pickups and number/letter their ends then list what each position would need to work, then you end up with a list that can be consolidated (some letters always grounded etc). Then draw yourself two rows of 12 squares and lay it out.
    We moved and I don't have my shop anymore, so layouts and this place (and playing) are my guitar time these days.
    Enjoy that Robbie Robertson setup.
    4,502
    Received: 110/0
    Given: 77/0
    Just a heads up that they do make a narrower version of the 4P5T superswitches with none of the terminals facing out... great for tele control compartments! (I had to undercut one tele cavity with a dremel to fit the original style superswitches.)
    https://www.ebay.com.au/itm/Pro-Seri...wAAOSwMQhajhwK
    Steve A.
    Dec 2013
    206
    Received: 25/0
    Given: 7/0
    Quote Originally Posted by Steve A. View Post
    Steve A.
    Thanks, Steve. The one in your picture looks like the one Allparts sells and is the only one I'm familiar with. I've stuffed one in my Tele, tight fit side to side and to bottom. I like putting something nonconductive on the cavity shield under it.
    4,502
    Received: 110/0
    Given: 77/0
    Here is a picture of the older style ones which are easier to wire if there is plenty of room...
    Steve A.
  1. Replies: 7
    Last Post: 12-29-2016, 03:31 AM
  2. Replies: 8
    Last Post: 11-15-2014, 07:56 PM
  3. New schematic for review
    By Howlin' Mad Mac in forum Theory & Design
    Last Post: 02-16-2011, 04:49 PM
  4. Newb in need of review
    By Dr Iley in forum Pickup Makers
    Last Post: 12-24-2010, 07:11 AM
  5. Review of Problem
    By Rattler66 in forum Debugging Your Build
    Last Post: 01-03-2008, 02:38 AM
