Page 5 of 5 FirstFirst 12345
Results 141 to 164 of 164
Thread: Deluxe Reverb problem
  1. #141
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    Quote Originally Posted by pdf64 View Post
    Issues that occur when gain is increased may be due to oscillation; closely examine the precise placement of wires in a real BF and review your lead dress against that.
    Ah that may be it! I do need to go back and recheck the lead dress anyway. Thanks, I'll see what happens, maybe take some pics and report back.
    0 Not allowed! Not allowed!
  2. #142
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    I will note that, with the chassis out of the cab, it doesn't exhibit any tearing sound. I warmed the bias back up from 18 mA to 20, so it's either that or the cab that's causing it perhaps.
  3. #143
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    I did barely tuck the wires into proper place but not much. They were good already. Who knows. I have it back in the cab so we'll see.
  4. #144
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    The cab is causing it, apparently. That's when it returns.
  5. #145
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
  6. #146
    don't forget the joker g1's Avatar
    Join Date
    Feb 2010
    Location
    Posts
    9,848
    Thumbs Up/Down
    Received: 70/0
    Given: 123/0
    I can't really make out the bad noise from the soundfile, but I don't have much for speakers.
    Often, a fault that shows up only in cabinet is due to vibration. Could be a bad tube, bad tube/socket connection, bad solder joint, dirty pot, etc.
    I would try applying a constant signal with the chassis out of the cab, then tap around the chassis with a chopstick or rubber mallet or something and see if you can recreate the problem.
    3 Not allowed! Not allowed!
    Certified Dotard
  7. #147
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    Quote Originally Posted by g1 View Post
    Sorry, should have had my phone closer to the amp. It's a quick tearing sound distinguishable from the natural distortion. Happens during sustained chords. I found last night it begins to occur at about 8 on volume.
    I'll go back in and do a more thorough check. I didn't observe anything odd when I poked around the lead dress previously. Would it more likely be caused by V2 or the 6v6s?
  8. #148
    Join Date
    Feb 2010
    Location
    Posts
    9,848
    Thumbs Up/Down
    Received: 70/0
    Given: 123/0
    It could be any tube. When it's doing it in the cab you can hold the tubes with a clean rag (don't burn your hand!) one at a time and see if you can make it stop. You can use a clean oven mitt too.
    Certified Dotard
  9. #149
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    Playing with the chassis out of the cab, the rca 7025 i had in there was still causing it. Substituted a tung sol, which doesn't have the problem, at least not out of the chassis. We'll see what happens in the cab.
  10. #150
    Supporting Member jmaf's Avatar
    Join Date
    Apr 2009
    Location
    BSB-DF
    Posts
    1,326
    Thumbs Up/Down
    Received: 12/0
    Given: 7/0
    Quote Originally Posted by tyler8611 View Post
    Remember we're blind-helping you here. So if you tell us the problem does not happen out of the cab then you find that it does, you've thrown us off. First thing I'd tell you it's the tubes but if it didn't happen out of the cab then obviously not, glad you found that.
    One other thing: if this is getting worse in the cab, means that when the tubes are upside down it gets worse, then there can be mechanical problem in the tubes.
    Also tubes are microphonic, they can be obnoxious when in a cabinet, the speaker shakes the tubes which replicate the vibration in the output, this matches what you describe when you play a chord, the underlying vibration.
    2 Not allowed! Not allowed!
  11. #151
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    Quote Originally Posted by jmaf View Post
    Could it be a mechanical problem in any tube? Meaning all the ones having to do with V2?
  12. #152
    Join Date
    Apr 2009
    Location
    BSB-DF
    Posts
    1,326
    Thumbs Up/Down
    Received: 12/0
    Given: 7/0
    Don't know what you mean by having to do with V2?
    What you describe, above volume 8 on sustained chords clearly sounds like feedback through the tubes, chassis vibration coming back through the tubes, etc. Could be a bunch of things.
  13. #153
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    I'll be tube swapping shortly.
  14. #154
    Join Date
    Feb 2010
    Location
    Posts
    9,848
    Thumbs Up/Down
    Received: 70/0
    Given: 123/0
    He's only getting the bad sound on the vibrato channel, so V2 or any other tubes that channel goes through, like V4, V6, and power tubes.
    1 Not allowed! Not allowed!
    Certified Dotard
  15. #155
    Join Date
    Apr 2009
    Location
    BSB-DF
    Posts
    1,326
    Thumbs Up/Down
    Received: 12/0
    Given: 7/0
    Oh, gotya. Thanks.
    Once he swaps tubes I guess we'll get a better idea.
  16. #156
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    Hey just wanted to finally update, busy weekend. The problem was solved by a swap. It was either the tremolo tube or phase splitter, since I did those at the same time. No more harsh ripping!
  17. #157
    Supporting Member Tone Meister's Avatar
    Join Date
    Aug 2012
    Location
    North Carolina, USA
    Posts
    612
    Thumbs Up/Down
    Received: 2/1
    Given: 2/0
    Really? After all that you'd swap two tubes at a time and forego the opportunity to pinpoint the issue? I'd have to know, but that's just me. Glad you got it sorted out, but I'd have to KNOW.
    Quote Originally Posted by km6xz View Post
    "I have come to the conclusion that the biggest risk to amp performance/reliability and "tone" is players reading the internet, not bad tube brands, and certainly not the often argued over capacitors."
  18. #158
    Supporting Member Steve A.'s Avatar
    Join Date
    May 2006
    Posts
    4,372
    Thumbs Up/Down
    Received: 19/0
    Given: 20/0
    Quote Originally Posted by Tone Meister View Post
    Good point but my guess would be the phase inverter. After 157 posts (just here on MEF!) I certainly hope that all of the problems have been solved.
    Steve A.
  19. #159
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    I can easily reinsert the previous tubes, recreate the problem and find out which was causing it, and I will. I was simply tired of doing one tube at a time and didn't think the trem tube would make a difference because several different tubes had already been in there while the problem was occurring. I had never changed the phase inverter until yesterday, mainly because it's a JAN blackplate. So I'm quite certain that was the one. But you never know.
    I'll reinsert the old phase inverter and trem tube and find out for sure. Honestly I just felt like playing once I heard the ugly distortion had gone. Thanks guys!
  20. #160
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    Quote Originally Posted by Steve A. View Post
    Steve A.
    I think so too, but I'll find out for certain and report back.
  21. #161
    Join Date
    Mar 2010
    Posts
    223
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Lack of high voltage is caused by open equalizing resistors under the circuit board under the dog house. You need to flip over the cap circuit board to get to them 220K 1W
  22. #162
    Join Date
    Aug 2012
    Location
    North Carolina, USA
    Posts
    612
    Thumbs Up/Down
    Received: 2/1
    Given: 2/0
    Sorry if I came across like I was busting your chops because that wasn't my intention. But I had been watching this thread pretty closely and watched as each issue got sorted out and its root cause identified. I'm a novice, so I pay attention to these threads and learn what I can from them, which many times keeps me from having to start a thread of my own. For every thread I've started here on MEF, I have easily solved dozens more issues on my own by searching for previous instances of the same problem I was having.
    This place is a cornucopia of in-depth technical knowledge. The best-of-the-best techs, designers, and engineers in the world unselfishly offer their assistance on this site, and I think we owe it to the next guy to clearly show the resolutions in our threads, including info on hard to find parts and non-conventional problem solving. In the end, it saves bandwidth and many times keeps the pros here from answering the same questions multiple times.
    So yes, please do swap those tubes back in there (hope you know which one went where ) so you can put a lid on this one.
  23. #163
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    No problem at all! I'm very grateful to you guys for helping and keeping me on the right path so I could find the problem and solve it. I hope this can be helpful for anyone who experiences the same or similar issues.
    I'm finally going to have time today to swap the tubes back in one at a time in order to find out for sure which was the problem and report back.
    I've had maybe two or three hours to play it since I sorted the problem. Sounds really great. No noise problems or grounding issues. All settings work properly, the effects are flawless. I'll see if I can record a clip through my interface or phone.
    Not sure if I posted pics of the tubes or transformers, but I'll go over that. PT is from Classictone. It's running 25-30v over schematic voltages. Maybe a mojotone would have produced a lower voltage but from the spec sheet, the classictone looked like it would. Choke and OT are mojotone.
    V1: rca 7025
    V2 : rca 7025
    V3: jan philips 12at7
    V4: rca 7025
    V5: EHX 12ax7 (replaced tung sol)
    V6: mullard ecc81(replaced jan 12at7)
    V7 and V8: JJ 6v6
    V9: JJ GZ34
    Speaker is a Weber 12F150 25w, no dope.
  24. #164
    Join Date
    May 2018
    Posts
    103
    Thumbs Up/Down
    Received: 5/0
    Given: 0/0
    Just did a swap and confirmed it was the previous phase inverter tube causing the bad distortion.
    4 Not allowed! Not allowed!
Thread Information
Users Browsing this Thread
  1. Fender Deluxe Reverb Reissue - Reverb Problem
    By bw1985 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-10-2018, 05:07 AM
  2. Deluxe Reverb Oscillation Problem - Reverb Driver stage?
    By waspclothes in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-13-2017, 12:45 AM
  3. deluxe reverb noise problem?
    By chuckb in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-25-2014, 09:39 PM
  4. Deluxe Reverb 5U4 problem
    By legaskins in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-08-2007, 01:45 AM
  5. Deluxe Reverb tube problem
    By Alexandre IV in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-18-2007, 07:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
