Page 1 of 5 12345 LastLast
Results 1 to 35 of 164
Thread: Deluxe Reverb problem
    May 2018
    103
    Received: 5/0
    Hi, I've built a deluxe reverb clone and have hit a snag. My screen and plate voltages on the 6v6s are both only 153v. I get a zero reading on pin 8 (through 1 ohm resistors), both mA and mV. I measured and set the negative bias voltage at -35. It's not a tube problem- already swapped another pair with same results.
    B+ is 440, then the second node drops all the way down to the 153v. The remaining power caps measure about as they should.
    Obviously there's no output, unless I dime channel 1 and get faint crackling notes. Vibrato channel is silent all the way up.
    Does this seem like a power cap or maybe transformer problem? I've checked the wiring and solder joints thoroughly.
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    4,862
    Received: 44/0
    Given: 32/0
    Quote Originally Posted by tyler8611 View Post
    Neither. There's a choke between the main B+ and the second power supply node that feeds the 6V6's screen grids. There would have to be something awful wrong with that choke for the screen grid voltage to drop all the way to 153V. Let's measure the resistance between those choke leads. Power OFF of course.
    Also possible the hi voltage nodes are wired in an out-of-order way.
    May 2010
    Sioux Falls, SD
    5,072
    Received: 52/0
    Given: 30/0
    I'm confused. You say, "B+ is 440". Then you say, "My screen and plate voltages on the 6v6s are both only 153v" The output tube plate node (B+) is before the choke and goes through the OT directly to the plates. You almost have to have something wired wrong.
    May 2018
    103
    Received: 5/0
    Ok I'll do that and report back. Also will check the doghouse again.
    May 2018
    103
    Received: 5/0
    I meant the voltage from pin 8 of the rectifier to the first power cap node. That is 440 and the second node feeding the screens is 153. The OT plate voltage is also 153.
    May 2018
    103
    Received: 5/0
    Between the leads is 154 ohms.
    May 2010
    Sioux Falls, SD
    5,072
    Received: 52/0
    Given: 30/0
    Yes. I understand. If you look at "pin 8 of the rectifier to the first power cap node", follow it up through the OT. It connects directly to the tube plates. If you measure 440VDC there, you should also measure it on the plates, unless you have a horribly bad, hot, melted standby switch. Measure DC on both sides of the standby switch. Is it the same on both with the switch closed?
    May 2018
    103
    Received: 5/0
    Voltages to ground of course.
    May 2018
    103
    Received: 5/0
    True and everything is wired correctly. Weird problem.
    Sep 2012
    Dogpatch-on-Hudson
    4,862
    Received: 44/0
    Given: 32/0
    True that. It's very weird to have 440V at one end of that choke and 153V at the other. If that's really the case it should be shooting flames. I'm still holding out for a mis-wiring. If you have an electronically knowledgeable friend have them give it a look-see. Sometimes a different set of eyes can pick out what's amiss.
    May 2010
    Sioux Falls, SD
    5,072
    Received: 52/0
    Given: 30/0
    IMO, the problem is before the choke. According to post #1 the plate voltage is also low. The plate voltage is derived "pre-choke". I'd like to know if the same DCV exists on both sides of the standby switch. Then, if we're good there, we see what the voltage is on the OT primary CT. It should be easy to follow the voltage and see where it's not. The B+ caps should be the same electrical point as the plates as far as DC is concerned, yet we have 2 different voltage readings, so I agree- something is not connected properly.
  12. #12
    Aug 2015
    Edmonton, AB
    44
    Received: 3/0
    Given: 4/0
    Don't know if this is your problem, but I replaced the filter caps in the dog house on my 78 SFDR.
    When I powered up, something was not right, I never measured any voltages and nothing smoked... but I knew something was "off".
    Powered down and checked my work... one of the cap leads I soldered into the eyelet was a bit long, and it missed the insulating card and shorted to the chassis.
    Maybe have a look in that area.
  13. #13
    May 2018
    103
    Received: 5/0
    I forgot to mention that I discovered earlier that on standby, the voltage readings were actually normal. Drop happens when I take it off standby. The switch is wired correctly with the leads going exactly where they should. Very strange.
    I also measured the resistance of the transformer and choke leads and they were fine. I drained the filter caps and measured those and the readings began around 90k and kept creeping upwards past 150k, so I'm not sure whether that's normal.
    I ran a flashlight under the filter cap board- no shorts. I'll have to keep searching.
  14. #14
    May 2018
    103
    Received: 5/0
    Quote Originally Posted by galaxiex View Post
    I thought that could be a possibility also so I looked under with a flashlight and saw nothing grounding out. It's a garolite board on standoffs so I was able to see.
  15. #15
    May 2010
    Sioux Falls, SD
    5,072
    Received: 52/0
    Given: 30/0
    Are you saying that, when you have the standby switch closed, your 440V B+ drops at the filter caps?
  16. #16
    May 2018
    103
    Received: 5/0
    The 440 B+ doesn't drop, but the second power cap node, 6v6 screens and plates drop down from normal range, while on standby, to abnormally low when switched from standby to play.
  17. #17
    May 2010
    Sioux Falls, SD
    5,072
    Received: 52/0
    Given: 30/0
    Again, please measure the voltage on both sides of the standby switch (switch closed) and tell us what you have. Then, measure the voltage on the center tap of the primary of the output transformer and report.
  18. #18
    May 2018
    103
    Received: 5/0
    Ok the voltage to ground from the rectifier side is now 480. No idea why or how it jumped. Voltage on the other side, connected to the choke lead and OT center tap is 156. The remaining filter cap nodes are 127v for the PI and 111 preamp.
  19. #19
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,913
    Received: 87/1
    Hi
    When you check something, please don't tell us it is "fine", please tell us what you measured. We don't know what you consider fine, and we want to know specific values.
    You have 440 at the standby switch? OK. What do you have at the OT CT?
    To me "second node" is the downhill side of the choke, ie the screens. It bothers me you have the SAME voltage at both plates and screens, even though ther is a choke and transformer between those two places.
    What voltages do you get there with power tubes removed?
    The standby switch should be on at all times here. ON means closed, the operate position. You should have your 440v on both sides of that switch.
  20. #20
    Supporting Member
    Staffordshire UK
    3,362
    Received: 9/0
    Given: 13/0
    It may be helpful to note that in a parallel thread on TAG, the OP has revealed a 'trickle bypass' mod to the standby arrangement Deluxe Reverb voltages - Page 2 - The Amp Garage
    Hence standby mode is not as we would normally know it.
    Most amps described as clones aren't; it's way better to provide an accurate schematic, rather than provide text descriptions of deviations to an existing design.
    Ok the voltage to ground from the rectifier side is now 480. No idea why or how it jumped...
    Maybe the mains voltage increased a few V? It's a good idea to monitor the mains Vac whilst undertaking such testing, as all voltages from the PT secondary will be a ratio of the primary voltage.
  21. #21
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,085
    Received: 110/1
    Given: 95/4
    PLEASE-ANSWER-WHAT-YOU-ARE-ASKED
    "True" is not an answer.
    "everything is wired correctly" is obviously not the case.
    EDIT:
    Is that so?
    If so, why didn´t you mention it?
    Please post the schematic of said "trickle bypass".
    And remember:
    "Standby ON means switch closed, passing current to the OT and power tubes"
    "Standby OFF means switch open, NOT passing current to the OT and power tubes"
    Nobody knows what trickle Bypass actually means but just from its name it looks like a BAD idea.
  22. #22
    May 2018
    103
    Received: 5/0
    Quote Originally Posted by pdf64 View Post
    I've used the standby switch trickle bypass mod on a tweed deluxe build, tweed bassman build and princeton reverb build. Never had a single problem with it.
    I will check and monitor the mains Vac and provide readings.
  23. #23
    May 2018
    103
    Received: 5/0
    EDIT:
    Is that so?
    And remember:
    This reminds me of that other forum. Jesus.
  24. #24
    May 2018
    103
    Received: 5/0
    I'll be providing exact detailed measurements all at once asap. I appreciate you guys.
  25. #25
    May 2018
    103
    Received: 5/0
    I think several of you guys may have missed this response. This is both sides of standby, switch closed. 480 on one side, 156 other.
  26. #26
    May 2018
    103
    Received: 5/0
    And I can certainly remove the trickle bypass if anyone thinks it's making this more difficult. But like I said, I've always used it. I think it's a sensible, but obviously not mandatory mod.
  27. #27
    Supporting Member
    Staffordshire UK
    3,362
    Received: 9/0
    Given: 13/0
    I've used the standby switch trickle bypass mod...
    Have you made any other deviations from the DR AB763 schematic and layout? http://schems.com/schematicheaven.ne...b763_schem.pdf
    Please take a bit of time and review it carefully against your build.
    We'll assume that a grounded mains cable and chassis have been used, and the death cap and switch omitted, unless you say otherwise.
    There may be something wrong with the switch.
    I suggest that it is removed from the circuit (at least that will remove terminology confusion), and that you then power up via a light bulb limiter.
  28. #28
    May 2018
    103
    Received: 5/0
    Deviations: 1 ohm resistors from pin 8 to ground on the 6v6s, a zener diode string to pull down an overvoltaged PT (also have zeners in my tweed deluxe), 100 ohm resistors on the pilot since my PT lacks a center tap, and copper bus preamp grounding.
    I don't have a light bulb limiter but I probably do have another new switch that I can substitute. I will check my parts bin.
  29. #29
    Sep 2012
    Dogpatch-on-Hudson
    4,862
    Received: 44/0
    Given: 32/0
    Deviations: a zener diode string to pull down an overvoltaged PT
    Are those zeners between hi voltage winding center tap and ground? We had a recent thread where that arrangement caused the bias supply to overcharge = excessively high bias voltage. Why? because the current path through the bias supply presented a lower impedance than the current path through the zeners, causing the bias supply to act in an unexpected way. (If there was an entirely separate winding for the bias supply, not just a tap on a hi voltage winding, it wouldn't be a problem.) This isn't a problem with a tweed Deluxe because it is self-biased, iow has no negative voltage supply for fixed bias operation.
    This may explain one reason for some of your Deluxe's misbehavior.
    Another, if the meaning of "standby" is inverted, and you have a trickle resistor to partially charge the power supply, it would be expected to see 440V one side of the standby switch and some lower voltage say 153 on the other, when the switch is open. When the switch contacts are closed, the same voltage will exist on both switch terminals.
  30. #30
    May 2018
    103
    Received: 5/0
    Yes, they're between center tap and ground. There is a separate blue 50v winding for the bias supply.
    I hear what you're saying on the standby, but somehow the reverse is happening. Doesn't make sense because the standby wires are going to their proper lugs on the switch. I will have to try a new one.
  31. #31
    Sep 2012
    Dogpatch-on-Hudson
    4,862
    Received: 44/0
    Given: 32/0
    Is that an entirely separate winding OR a tap on the hi voltage winding? Most transformers intended for Deluxe have the tap. I say most because I haven't seen 'em all, maybe somebody makes a Deluxe power transformer with an entirely separate bias winding.
    If the "sense" of the standby function is inverted then a new switch won't help. Easy enough to apply an ohmmeter & find out which direction to point the bat so that the switch is closed; when the meter reads zero ohms, that's the "operate" position and should allow current to pass thru the power supply to run the amp. Yes it's a bit confusing: Fender and lots of other companies print "standby" on the chassis so that when the bat is pointed to the lettering, that's the operate position, and bat away from the lettering is amp on standby, iow not passing signal. Might be all you need to do is invert the switch position and that's that.
  32. #32
    Supporting Member
    Staffordshire UK
    3,362
    Received: 9/0
    Given: 13/0
    I think Leo's hunch is right, the zeners may be screwing up the bias supply.
    I suggest to take them out of circuit and review.
    I think that a light bulb limiter is second only to a multimeter as being most important resource on a tech's bench.
    I suggest to build one before proceeding further.
  33. #33
    Feb 2010
    9,848
    Received: 70/0
    Given: 123/0
    Don't go by the looks of the lugs on the standby switch, measure resistance. Zero ohms is the closed position.
    Certified Dotard
  34. #34
    May 2018
    103
    Received: 5/0
    It's the one here: Fender Power Transformer, Deluxe, Deluxe Reverb, Tweed Tremolux, 125P23B, 025130, 041316, 120V
    And you were right about me stupidly forgetting the direction of the standby switch. Unbelievable. Haven't dealt with blackface amps in a long time. Totally slipped my mind!
    Now, the problem is the bias is only 4 mA max. So the zeners may indeed be causing this to happen. Currently, the bias tail resistor is 10k. The range resistor, which I may try changing next, is the standard 470 ohm. I was thinking of upping it to 1.5k, which was the next highest metal oxide resistor I could find.
    Then again, maybe I should go ahead and remove the zeners. I'll let you guys chime in.
  35. #35
    May 2018
    103
    Received: 5/0
    Thanks I will look into that.
  1. Fender Deluxe Reverb Reissue - Reverb Problem
    By bw1985 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-10-2018, 05:07 AM
  2. Deluxe Reverb Oscillation Problem - Reverb Driver stage?
    By waspclothes in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-13-2017, 12:45 AM
  3. deluxe reverb noise problem?
    By chuckb in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-25-2014, 09:39 PM
  4. Deluxe Reverb 5U4 problem
    By legaskins in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-08-2007, 01:45 AM
  5. Deluxe Reverb tube problem
    By Alexandre IV in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-18-2007, 07:10 AM
