Results 1 to 5 of 5
Thread: Overdrive pedals make my AC30 speaker crackle
    Junior Member
    May 2018
    7
    I have a VOX ac30cc2 amp,
    and I have a 808 Tubescreamer, and a Crowther Hot Cake,
    when I turn either of these pedals on, they both add a crackle to the speaker.
    To clarify, apart from the overdriving / gain / distrortion that tehy add, there is also another crackling sound that sits above this, almost like the speaker is faulty or failing.
    But if I play one of my distortion pedals - MXR Distortion +, RAT, Big Muff Opamp, I don't get this extra crackle.
    It just happens when using the Tubescreamer and the Hot Cake.
    Does anyone else experience this?
    i've turned presence, gain, etc. down on both pedals, and am only using them one at a time, but it still happens.
    I also flipped the internal switch on Hot Cake to the Bluesberry option, to see if that helped , but it still happens.
    I also tested it with the amp set to Hot and Warm (back of amp selector switch) but it happens in both modes.
    Senior Member Malcolm Irving's Avatar
    Dec 2014
    Derbyshire
    364
    Given: 4/0
    Can you try those two pedals on a different amp?
    Junior Member
    Jun 2018
    4
    Check your cables is my first goto. maybe a contact cleaner solution.
    Junior Member
    May 2018
    7
    Quote Originally Posted by MatronMother View Post
    I will give that a go, although I did try a few different cables.
    And both pedals do not make this occur to the speaker when I play through my hot Rod Deluxe III combo.
    Junior Member
    May 2018
    7
    Quote Originally Posted by Malcolm Irving View Post
    Oh sorry Malcolm I should have mentioned that I've played them through my hot Rod Deluxe III combo and the problem does not occur
  1. Deluxe reverb shrills too much with overdrive pedals
    By Jesse Rev in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-18-2017, 01:43 AM
  2. Help! Crackle from Mackie/RCF ART 300a powered speaker
    By dukeh62 in forum Music Electronics
    Last Post: 12-09-2013, 12:23 PM
  3. Rose Morris AC30 Pop and Crackle
    By Ted in forum Vintage Amps
    Last Post: 06-02-2013, 10:51 AM
  4. 5F1 - hum and speaker crackle
    By electrochronic in forum Debugging Your Build
    Last Post: 01-26-2010, 09:32 AM
  5. Replies: 1
    Last Post: 01-12-2009, 07:50 PM
Tags for this Thread
