Valveking mh 20 negative feedback question
Originally posted by Rod View PostNeed some help here.
If i lower or raise the R38 resistor in the schematic bellow, wich i think is the presence resistor, what results will i have?
http://music-electronics-forum.com/a...60-vk-20mh.png
[ATTACH=CONFIG]49005[/ATTACH]
What exactly are you trying to accomplish?
Steve A.The Blue Guitar
www.blueguitar.org
Some recordings:
Attached is the full schematic, i think that the amp has a little to much presence, i want to improve this, and im triyng to see if changing the R38 resistor value in the negative feedback loop will increase or lower the presence.Attached Files
Originally posted by kmensik View PostRaise the value to lower the presence. Try a 2k or 5k pot. Or you can raise the C23 cap to make it bypass more mids.
R78, R38 and C23 form a cathode bypass for highs, whereas R77+C5 form a full range bypass.
I raised the vale of the R38 to 1.5K in the negative feedback loop, and it raised the presence, it did the oposite of what i wanted.
Originally posted by Rod View PostHI!
I raised the vale of the R38 to 1.5K in the negative feedback loop, and it raised the presence, it did the oposite of what i wanted."Take two placebos, works twice as well." Enzo
"I think that the presence could be also of the El84 tubes"
Not sure what you mean.
when you say too much presence, you are talking about high frequency response right?
may not be what you think, depends on the tube health mabe they are worn and loosing lows? just asking because its not clear what your trying to accomplish.
I would not mess with the bias, if it were me, I would try some values around the c23 .1 should lower the freq a bit.
if r38 at 1.5k "went wrong way" try 1k ohms and see? ( that should brighten things even more ) as its a 180 now.
according to the schematic i am looking at.
If change the location of the negative feedback loop resistor R78 just to after R23//C59, will this change the presence of the poweramp?, in what way?
ValveKing2_20MH.pdf
If I change the location of the negative feedback loop resistor R78 just to after R23//C59, will this change the presence of the poweramp?, in what way?
There must be someone that can help me with this question.
ValveKing2_20MH.pdf[/QUOTE]
