Results 1 to 3 of 3
Thread: LG home cinema issues
    New Member
    Jun 2018
    2
    hi guys,
    Anyone in the know about home cinema systems? do the modern amps have fuses protecting each channel?
    long story short - i bought a second hand LG HB405 to replace my temperamental LG BH7430p unit on the understanding the only issue is laser needing replacement but got it all wired up to discover the surround right channel is not working l changed wiring, swapped speakers and the channel is dead.
    May 2010
    Sioux Falls, SD
    5,210
    Received: 191/0
    Given: 157/0
    There may or may not be fuses. Every such piece of gear is different. The first step would be to chase down a schematic/service manual. Do you hear any hiss or anything at all out of the non-working channel? If you hear any noise indicating the amp is working, you might try a factory reset. Sometimes they just get "confused". But again, you'll probably need a manual to find out how to factory reset the thing. If you hear no noise at all, it's probably time to dig in.
    New Member
    Jun 2018
    2
    thanks for your prompt reply,
    no hissing at all from that channel. i factory reset the unit from the OSD as i thought the same as you, that maybe it was just a little confused but no such luck there.
    i also attempted to find a service manual but lead to a load of pop ups
  1. Baldwin Cinema II Schematics - Wiring Diagram
    By fearlessleeder in forum Schematic Requests
    Last Post: 12-23-2017, 11:48 PM
  2. LG XA146
    By pdf64 in forum Schematic Requests
    Last Post: 02-08-2017, 01:35 PM
  3. Home Brew SVT Hum Issues - Suggestions
    By jakejoseph in forum Debugging Your Build
    Last Post: 03-28-2011, 10:32 AM
  4. Home Brew SVT Bias Issues
    Last Post: 02-28-2011, 05:07 PM
  5. Stageworks LG-8 PA
    By Wonker in forum Other Amps
    Last Post: 06-13-2009, 12:48 AM
