Originally posted by olddawg
View Post
Carvin Legacy 212 problem
Just to update....I haven't had the chance to get any freeze spray so I removed Q5 from the board and it tested ok with a basic ohmmeter test.
Originally posted by Mick Bailey View PostThat points towards a thermal fault. My favourite go-to for these is a source of heat (hairdryer will do) and a can of freeze spray. My gut feeling is to start with Q5 and then the associated components. With the amp running, warm up the board in that area until the noise worsens and then target the freeze spray on individual components and see which responds to chilling. You may need to heat/freeze a few times to pinpoint the fault.
Very often a transistor will check out OK with a DMM. The instrument doesn't test the transistor under operating conditions and in any case if it's working but noisy you won't 'see' the noise with your meter - it can be less than a single digit resolution. Given that you've already removed it you may be better off replacing it with a new part anyhow to save further disturbance if it does turn out to be that transistor.
Originally posted by guitardog View PostJust to update....I haven't had the chance to get any freeze spray so I removed Q5 from the board and it tested ok with a basic ohmmeter test.
While that transistor's out, bypass from (right side of) C66 to (left side of) C67 with some alligator clips, that should give you an idea if it's (or the associated circuit) causing any problems.
Also, is that static noise constant or intermittent? If it's constant, I'd say one of the coupling capacitors might be leaking DC into the circuit.Last edited by m1989jmp; 06-15-2018, 07:50 AM.
I was planning on replacing Q5 regardless. Unfortunately it's obsolete and not readily available. I am sure there is an equivalent available, I just haven't found it yet.Originally posted by Mick Bailey View PostVery often a transistor will check out OK with a DMM. The instrument doesn't test the transistor under operating conditions and in any case if it's working but noisy you won't 'see' the noise with your meter - it can be less than a single digit resolution. Given that you've already removed it you may be better off replacing it with a new part anyhow to save further disturbance if it does turn out to be that transistor.
Originally posted by m1989jmp View PostI was checking out the schematic again, and I've noticed B1 connection that's bypassed when jack is plugged into either SEND or RETURN. Have you ruled out that piece of wire/track and associated joints are fine?
MPSW42 is a 300v part. I list them i nmy stock, I'll look.
But wouldn't an MJE15034 work? Yes it is a larger package, 350v part.
https://www.mouser.com/datasheet/2/3...4-D-112132.pdfEducation is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostMPSW42 is a 300v part. I list them i nmy stock, I'll look.
I saw that. I am no fan of NTE, but it ought to work OK. It isn't like it has to match something else in there. The MJE part is something I already have in stock.Education is what you're left with after you have forgotten what you have learned.
Update: With Q5 removed, the noise is gone and I have input on both channels. I will replace Q5 and was thinking I should go ahead and replace C66 and C67 while I am at it. What do you guys think? Should I go ahead and replace the main filter caps while I have it apart?
Thanks and Happy Father's Day to all the Dads here!
P.S. I found what appears to be a suitable replacement for Q5. It's readily available and inexpensive. https://www.fairchildsemi.com/datasheets/KS/KSP42.pdfLast edited by guitardog; 06-17-2018, 03:59 PM.
I'm against shotgunning, but if a part costs pennies and is suspect I'll replace it as a matter of course to save time. When it comes to main filter caps, how old is the amp and are they leaking or bulging? Bear in mind that anything you do to an amp increases the risk of something going wrong. With repairs I tend to concentrate on fixing the principal fault and making sure the amp is working before touching anything else. That way I know the last-known good configuration if something is then wrong. Let's say you replace the transistor, the two caps and the filter caps but you then have a hum that wasn't there. Was the transistor faulty from new? are the replacement caps good? did I mis-solder a joint? did I splash some solder somewhere? Did I disturb something? Is one cap in backwards?
My advice is always to minimize the amount of repair work to that which is necessary, baseline the repair and then carry out additional work afterwards.
Originally posted by Mick Bailey View PostI'm against shotgunning, but if a part costs pennies and is suspect I'll replace it as a matter of course to save time. When it comes to main filter caps, how old is the amp and are they leaking or bulging? Bear in mind that anything you do to an amp increases the risk of something going wrong. With repairs I tend to concentrate on fixing the principal fault and making sure the amp is working before touching anything else. That way I know the last-known good configuration if something is then wrong. Let's say you replace the transistor, the two caps and the filter caps but you then have a hum that wasn't there. Was the transistor faulty from new? are the replacement caps good? did I mis-solder a joint? did I splash some solder somewhere? Did I disturb something? Is one cap in backwards?
The latest: I replaced Q5, C66 and C67 today. I put it all back together, and powered it up. I let it warm up for about a minute, then flipped it off standby. No noise. All controls at zero. I grabbed a guitar and started playing on the lead channel. It sounded good. I pushed the button to try the clean channel, there was a slight "pop" sound and bam, the static was back. So now I'm pretty much back where I started. Defective transistor from the factory? I did get 2 of them in the event that happened.
A few questions:
1) When you switched to the clean channel, the noise started. When you switch back to the lead channel, does the noise go away again?
2) What are the DC voltages on Q5 (E,B,C)?
3) Do you have a scope?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
