Results 1 to 4 of 4
Thread: Help with this HSH diagram
    Supporting Member Tone Meister's Avatar
    Aug 2012
    North Carolina, USA
    626
    Received: 13/1
    Given: 10/0
    NOTE: I believe these wire codes are correct for modern Bill Lawrence humbuckers (Bill & Becky, not Bill Lawrence USA, which are different).
    http://wildepickups.com/Wiring___Tech_Info.html
    White = SS positive lead for South Coil (+ when used as regular humbucker)
    Green = SF ground for the South Coil
    Red = NS positive lead for the North Coil
    Black = NF ground for North Coil (- when used as regular humbucker)
    Blue= Common ground
    Grounding the green/red combination shuts off the North Coil, which works out fine for the neck position. I'm not sure to go about shutting off the South Coil for the bridge in order to have outside coils working in positions 2 and 4. In most detailed wiring diagrams you see the NF/SF tied together, but BL has the green/red or SF/NS tied together. What gives there?
    Not sure if I have all the info need to get the help I'm seeking, but hopefully someone here can spot any problems and suggest corrections as needed. Guitar is an HSH Ibanez (S540 from 1998) and I am upgrading the pickups to Bill Lawrence (wildepickups.com). I've made a rough drawing, but my uncertainty is with splitting the bridge humbucker and leaving on the outer coil.
    Neck = L500XL
    Middle = L280SM
    Bridge = L500XL
    Here is the configuration I want:
Name:	New wiring.jpg
    Bill Lawrence humbuckers have the South Coil on top and North on bottom.
    Here is my drawing:
    What I think I have wrong is this: I don't think this wiring scheme will shut off the inner (S) coil for the bridge pickup. Or is this drawing correct?
    Quote Originally Posted by km6xz View Post
    "I have come to the conclusion that the biggest risk to amp performance/reliability and "tone" is players reading the internet, not bad tube brands, and certainly not the often argued over capacitors."
    Aug 2012
    North Carolina, USA
    626
    Received: 13/1
    Given: 10/0
    School me on coil-splitting humbucker pickups
    Started a thread on a wiring configuration HERE trying to get some help verifying whether my drawing is workable or not.
    I'm confused about a couple of things relating to coil splitting and hum canceling when doing so. I have a set of current production "Bill & Becky" Bill Lawrence L500XL (Wilde Pickups) humbuckers and the configuration is different in a few ways. The main difference is the coil split is at the SF/NS (green/red) junction where most others are NF/SF. Does this even matter? I sussed out the wiring codes with a meter since they are not published anywhere for the original Bill Lawrence design.
    I know grounding the red/green wire will shut off the North Coil, but how do I go about shutting off the South Coil for the bridge pickup? These are Zebra, so flipping them is not an option. These L500XLs have S coil on top and N coil on bottom, for whatever that's worth.
    Any info you will share is appreciated.
    Here is the scheme I want
    And here is my drawing
    4,444
    Received: 63/0
    Given: 55/0
    If you want all 5 switch positions to be humcancelling and in phase the two coils must be RWRP with respect to each other. You might need to flip the magnet on one or both of the humbuckers to accomplish this. Once the magnets are oriented properly you can use small test clips on the coil leads to figure out the wiring for humcancelling in-phase operation.
    If the bobbin colors don't matter you can rotate the hb 180 degrees rather than flipping the magnet (which must be done correctly, you might want to ask first.)
    Steve A.
    Aug 2012
    North Carolina, USA
    626
    Received: 13/1
    Given: 10/0
    Tried to edit the original post, but too much time has passed.
    Check this and see you think this is a workable drawing for the configuration I want.
    Here's what I want
Name:	Bill Lawrence Humbucker - 4 conductor.jpg
  1. Super HSH Wiring scheme (question)
    By craigslee in forum Guitar Tech
    Last Post: 11-01-2017, 11:25 PM
  2. Replies: 8
    Last Post: 11-15-2014, 07:56 PM
  3. Two modes for an HSH Setup
    By nicholaspaul in forum Guitar Tech
    Last Post: 07-21-2013, 03:03 AM
  4. HSH 5 way switch 1/1
    By jakeac5253 in forum Guitar Tech
    Last Post: 03-15-2010, 09:21 PM
  5. Another HSH Wiring Question...
    By Jeff Callahan in forum Pickup Makers
    Last Post: 08-09-2009, 07:06 PM
