Results 1 to 3 of 3
Thread: Active resonant HP & LP filter PCB for Strat
    New Member
    Jun 2013
    2
    Given: 1/0
    Hi There,
    Posts on this seem incomplete/unresolved or I didn't understand them, so sorry if this is easy/obvious.
    GOAL
    I'd like to implement into a Strat:
    • 2x Active resonant Bandpass filters
    • 2x Concentric pots to control frequency and Q
    • 2x DPDT switches to activate the filters independently
    • Be small and super-simple so it will fit into a Strat using a 9v (will route more room)
    EXAMPLE
    https://www.electronics-tutorials.ws.../filter_7.html
    I found this schematic but am unclear how to integrate it into a guitar becase as I understand things, the guitar stuff (pickups, volume, tone pots) are before the output jack:
    • Does the circuit require modification to integrate into a guitar?
    • How does the 9v power integrate into the circuit?
    EXPERIENCE
    While I've made pedal kits and wired parallel/series/out-of-pase wiring in a Strat, I know little about schematics and nothing electronics design.
    Also, is DesignSpark PCB good for translating schematics into PCBs (never done that before)?
    Any help or pointers would be much very appreciated (go easy, I'm super green when it comes to electronics!)
    Cheers
    Ben
    4,449
    Received: 69/0
    Given: 57/0
    I keep looking at the $249 Empress Parametric EQ as they are great for sculpting the sound of your guitar, or the BYOC kit for half that price. However trying to fit a good portion of that circuitry into a strat would be quite a challenge.
    https://empresseffects.com/products/paraeq
    https://buildyourownclone.com/products/paraeq
    Is there a particular reason that you want it installed onboard? I imagine that there are custom guitar makers who would build such a guitar for $2K-$3K.
    If you wanted to build something yourself you might start with the BYOC kit and then replace the pots you did not need with fixed resistors or trimpots (for internal adjustments) and then etch your own custom PCB.
    As for powering such a device I would use an external battery box connected to the guitar via a stereo cable since the batteries would need to be changed quite often.
    Dual concentric pots for guitars are usually available in just a few resistances like 250K. For other values you might check electronic suppliers like Mouser. Be sure to get all of the specs so that you can find the appropriate sized knobs.
    Or you could wait a few years for some company to come out with a digital pedal controlled by bluetooth from an LCD screen embedded in a strat pickguard that could do all of that and so much more... it could happen.
    Steve A. (one of the moderators)
    P.S. I can move this thread to the Guitar Effects subforum if you want as those guys know a lot more about electronics than guitar techs.
    2 Not allowed! Not allowed!
    New Member
    Jun 2013
    2
    Given: 1/0
    Thanks heaps for the reply Steve, I'll checkout your links (I've built a few BYOC kits).
    I also found these: https://www.guitarfetish.com/Onboard...Kit_p_573.html
    So based on your reply, an off-the-shelf option would be the path of least resistance.
    If you could move the thread to the Guitar Effects subforum, that would be great (sorry for the confusion).
    Cheers
  1. Replies: 7
    Last Post: 07-11-2017, 10:54 PM
  2. Replies: 2
    Last Post: 07-21-2013, 03:49 AM
  3. Circuit Advice On Strat Active Device
    By tube power in forum Guitar Tech
    Last Post: 01-27-2011, 01:56 PM
  4. EMG active in a strat with passive pickups?
    By Switchstrong in forum Guitar Tech
    Last Post: 12-13-2009, 04:42 PM
  5. Replies: 13
    Last Post: 10-16-2007, 02:20 AM
