Do you still have the bad pot? If so, do us a favor, measure resistance from any of the legs to the metal frame of the pot.
Princeton Reverb Reissue Tremolo issue
Originally posted by LarBal View PostFrom legs to frame :
in full ccw position, in leg 65k, middle 325k, out 325k
in full cw position, in leg 65k, mid leg 65k, out leg 325kThis isn't the future I signed up for.
There was your problem, the pot had a internal path to ground and so made a voltage divider of itself. Good call on replacing it. Probably some bit of foreign material inside it.Education is what you're left with after you have forgotten what you have learned.
