I have a Mesa Boogie Bass 400+. It takes 12 6L6 power tubes and, like most Mesas, has no bias (self biasing.) Only one tube is bad. I bought them all together as a matched set but wonder if I will do damage to the amp by only replacing the one bad one. Anyone know? Also, where is a good online place to buy a replacement set if need be? Thanks.
how much difference does a matched set make?
Most any good seller can make up a set of 12, pretty close if not real match. And it depends on what each considers "matched." 5%-10%-20%? For example Groove tube sells their tubes "graded" into 10 levels - I think. I don't really know what each level really equates to, but they do it. That means that WHATEVER the whole range might be, all their tubes are lumped into 10 grades. And they have a spiel for each grade to make it appealing to you. On the other hand, the identical tubes when sold through Fender - Fender Groove Tube - the tubes are broken down into only three grades - red, white, or blue. And I have zero idea what each of those means. But though they are more or less matched, it is far less precisely than the 10 grade system. And both are from Groove.
But assuming that match really does mean something, you shuold realize that most amp makers do not bother with matching tubes. It most certainly will not HURT your amp to have an odd tube in it.
And whether you would hear a difference betwen matched tubes and random ones is hard to say. Someone might, and a lot of people won't. Especially in a set of 12. In a set of two, one side way off from another would be more noticable than in a set of 12, where the six on each side will tend to average out. The sonic difference of a matched set will be subtle. The main advantage to me is that matched sets are more likely to balance the amp, and that means B+ ripple wil cancel out in the power stage. That means unmatched tubes will add more hum in the power stage than matched. Not tons, but can be noticable.Education is what you're left with after you have forgotten what you have learned.
If you bring the amp to a good tech who has some tubes in stock, he might be able to find you a tube from his stash that is a reasonable match to the 11 you already have.
If it was my own amp, I'd just get another tube of the same make and type, and stick it in there. The worst it can do is draw more idle current than the others, and start redplating, in which case try another one. Enzo already explained about the grading system that Fender/Groove Tubes use, so if you have Groove Tubes in it, you can probably just order another single tube of the same grade."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
are not mesa tubes made in china?
ive had a few buddy get those and it seems they came with made in china stickers on them.
i had two friends grab two mesas and put in an amp and they didnt sound as good as the 30 year old ones that were in there...and the mesa were new!
Ah, the old tube-matching controversy. This all depends on who you speak to.
OK, so I am fairly new around here, but being in the business 30+ years kinda makes me an old-timer, or at least an old warhorse! If you talk to guys like me, we will tell you that matching means squat, and that unmatched sets might even SOUND better, because the tubes will clip at different levels and lend their own harmonic qualities to the signal. In addition, ALL of the tubes we regard as "sacred" e.g. RCA 6L6, Tung-Sol 5881, Mullard EL34, etc. were NEVER matched by tube manufacturers. The amps sounded great and they lasted (the amps AND the tubes that is).
Now, of course, no push-pull tube amp has perfect symmetry anyway, so asymmetrical clipping, which is what makes more amps interesting, always exists to some degree. So, is tube-matching an attempt to remove that variable from the overall equation? I can tell you this: many tubes I receive as matched in my shop DON'T match, even though they are labeled as such, and also, tubes don't necessarily age at the same rate either. Therefore, if they match when new, after a few weeks, they might not match at all.
Of course, you can argue this from the technical side, but when all is said and done, it's about TONE.
Truth or fiction? I have my own theories.
I'm in general agreement with most comments, but: Let's not mistake "static" 0 DC - "match" for "dynamic" match. While dynamic mismatch may sound good static mismatch may be large enough to DC saturate one side of an OT primary and/or cause other mischief as a system melts. One tube out of 12 probably ain't gonna make that much difference.
Secondly one of the reason that the "sacred" tubes were not matched (and every manufacturer I know of did offer "matched" sets - and I remember buying them for HiFi enthusiasts 35 years ago or so - was that overall tolerances were better. Assembly lines had been in place for generations, engineers were trained in tube technology and didn't learn it "post graduate" on-the-job, and materials were better sourced with, again, generation old mica spacer fabricators for example. So there was much less need for matching as a greater number of tubes came off the assembly line "matched."
The amp makers don't bother to match tubes, but I prefer them for hum balance reasons. it is a small thing for sure, but I like it. That is what the bias balance control on Fenders was for, balancing the current through the OT.
I have an old B18X Portaflex Ampeg at home. The last pair of 7027 I bought for it was RCA 7027MP. Factory matched pair. I suspect RCA was not just scamming me, I think they really did match them up in some fashion.Education is what you're left with after you have forgotten what you have learned.
In marketing-speak, that's what self-bias means these days.
Customers have been brow beat with the "bias must be adjusted at all costs" mantra for so long, they expect it. So saying an amp has non-adjustable bias is a turn off, but self-bias sounds like a good feature.
When I hear "self-bias," I get a mental image of an amp that somehow senses current and then a servo circuit adjusts voltage to compensate.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostIn marketing-speak, that's what self-bias means these days.
I attend NAMM every year as part of my business. Let me tell you, they sure do pile on the bullshit to sell the same ol' stuff year after year.
Enzo, your comment "Customers have been brow beat with the "bias must be adjusted at all costs" mantra for so long, they expect it" is interesting, because it is tangent with the whole "matched tube" thing.
When we service SS power amps, we either match output transistors ourselves, or purchase matched sets from the manufacturers we service (Crown, QSC, etc.). When a device, such as an output transistor, is current-operated, and handling A LOT of current at that, you MUST make sure that the current-sharing characteristics are in tight tolerance, or you can have a catastrophic meltdown on your hands. But power tubes? Man, I just do NOT totally buy into it. To a point perhaps, because of the widely-varying quality control of newly-manufactured tubes, but as long as the tubes are GOOD, there will not be any meltdowns of tube amps due to the use of unmatched sets of power tubes. In 30+ years, I've NEVER had a comeback due to unmatched tubes when I did use them. I HAVE had MANY cases of a single tube in a matched set going nuclear however. Again, it's all marketing. We can thank Aspen Pittman (Groove Tubes) for that.
