Laney AOR 100 series II, mods? The schematic is posted here>> http://launch.groups.yahoo.com/group...s_Fixes/files/
I want to bypass the effects loop as to eliminate any solid-state signal path. I am concerned if I can simply hard wire a jump from the FX loop input to the Power amp 12ax7 stage. I do understand I would have to desolder the FX loop in and out points as to not feed a signal to it.
Another concern is the voltage at this stage, is there any other mods to the path post master volume prior the 12ax7 in the power stage.
If you really want a challenge? I am trashing the AOR channel which is way to fuzzy. I would like that AOR channel to be allot more JCM800 sounding, so I am going to mod the AOR gain on the V1A to JCM specs. Typically the distortion comes from the gain from the input tube, correct? I am not quite sure if I need to change the AOR master volume or leave it alone.
Any advice would be great as I am a self taught builder having moded several amps and effects.
