hey guyz!!
OK. here's is second pickup. It is same p-90 style pickup.
I'll mention the apparent glitches, but i dunno if they matter or not.
firstly,
my winding wasn't too good (9300 turns of 41 gauge wire). There was a break once, I solded the wire and spayed lacker. It was a bit loose towards the end.
secondly,
I used 2 magnets are .6 cm x 6 cm x .3 cm. I don't know what type it is. May be ceramic(by appearance).
thirdly,
I didn't used a metal base plate.
I directly this to the connected this thing to the input jack.
I am getting some sort of an output... but definitely not a musical one.... its like saws on metal .... a weird buzzing to be more accurate.....
I also connected this pickup to my PC, to check the input level. When i tap my PC casing. I get a sound. It is amplifying it and very clearly. Just like a drum
its a pretty mean mess-up.... i feel pretty royally fudged! what should i do !!
I also posted this message in my other thread pickup building help, but that one is too many posts and this thing is little different.
firstly,
secondly,
thirdly,
