I have an old Fender Super Twin on the bench. Complaint is intermittant "graphic" EQ. The 100Hz control has an intermittant inductor. The lead coming out one end moves, and with it continuity comes and goes. SHort of trying to grind the epoxy out of the end in hopes of repairing the part, I need a replacement.
The part is Fender 011946. Hard to believe, that ONLY 30 years later, Fender no longer lists the part.
The inductor is 2.5Hy. It is 1" long cylinder, half inch diameter. ROughly the size of a 5 watt cement resistor. ANd heavy - feels like ferrite.
ANyone have one or recommend a source?
