MARK IV EQ Scaling
  • MARK IV EQ Scaling
    Hi,
    You all know that those inductors are hard to get. In the same time there's a wide selection of inductors of up to 100mH so I was thinking of scaling down the tone control section by a factor of 10.
    The values for the 80Hz section for example will be:
    OLD - NEW
    470 Ohm - 47 Ohm
    1H - 100mH
    3.3uF - 33uF
    pots 50k - 5k
    Did I get it right and do I need to tweak the circuit any firther to make it work with the new values?
    Since it's a solid state EQ anyway, perhaps it's easier to use opamps instead of inductors? It should be fairly easy to find a schematic for a generic opamp-based graphic EQ, and adjust it to get the desired frequency bands.
    E.g. something like this:
    http://www.generalguitargadgets.com/pdf/ggg_eq6b_sc.pdf
      You scaled the characteristic impedance of the tuned circuits by a factor of 10, so you'll need to reduce every other impedance in the circuit by a factor of 10 too, and make sure any active devices can source 10 times the current that they had to before, and have 1/10 the output impedance.
      The smart money is indeed on replacing all those inductors with gyrators.
