I was at band practice yesterday and i started to hear a popping noise. i was using high gain at the time so i tried using less gain, playing clean, switching inputs and making sure all the tubes were in all the way and working and with every alteration i still had a popping noise. i decided to just keep playing and about halfway through one of our songs my my amp goes out. i look over and the light is off but the stand by and power switches are still on. i switched amps for the remainder of practice and tried turning it on again earlier today with the same results. can anyone tell me what is wrong? any help would be much appreciated. thank you.
fender hotrod deville 212 trouble! (no power)
No power at all? No lights on at all? First thing that comes to mind is that an output tube went south and blew a fuse. Have you worked on things like this before? If not, be sure to read up on safety issues involving electronics. If you feel you can attack it yourself, press on and ask questions, but be VERY careful. Or have a local tech check it out. Replacing the fuse and pressing forward is not the answer. The fuse blew for a reason, VERY unlikely the fuse blew because it was tired.
thanks for the suggestion. the only experience i have as far as maintenance is with the guitar itself. i have no idea what to do with amplifiers at all. the only real electronic work i have done is installing pickups. would i be able to find a good tech at my local guitar center? it seems like a question with an obvious answer to me but i dont have any idea what to do with my amp and i dont want to get jerked around. how would i be able to identify a blown fuse?
take it in
Gary is right. based on your questions you should really take this in to a tech who knows what he is doing. Volts and Ampms can do alot more than just curl your hair, not to mention making a smal repair in to a realy big one. Go ahead and call your glocal guitar shop or the shop you bought the amp from and they'll recommend a local tech.
Mike
Yes, the voltages inside this amp can KILL YOU. I agree, most likely a power tube failed and blew the fuse. A new fuse might wake it up briefly, but the tube wil still be bad and will blow th new fuse soon enough.
New power tubes and a fuse MIGHT be all it needs.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Corygreen146 View Postcame across this page and noticed you had the exact same problem i have with my deville 212. could you let me know what the problem was and how you fixed it. Thanks!
If you're debugging an amp, go read the tube amp debug page at GEOFEX for a disciplined way to go about it. That's been on line for about a decade now, and as yet no one has told me that any part of it is wrong.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
