klon centaur
  • klon centaur
    Does a schematic exist for the klon centaur?
    Not a legit one. If you need it fixed, send it to Bill Finnegan. If your goal is cloning, don't bother. It is a LOT more complicated, and involves a lot more component selection, than people realize.
      http://soulsonic1978.tripod.com/illu...pic_id=1105255
        Cool! I don't see anything funky in there, except for maybe the 1N34 germanium diodes, so I'm not sure what Mark means by a lot of component selection. Do you have to buy 100 1N34s and audition them?
          klon vs maxonod820
          Now that ive had the chance to do some digging.From what i read the maxon od820 beats the klon pretty much hands down.So you know what that means....uh..ill have to get one.Ijust got a pro analog dual drive early model with oc44s.It too needs to be in front of a pushed amp.Not for the bedroom.I like it as well as my second gen. rat.Thanks for your response guys.Glad I joined.
            teardrop amps
            Where does the teardrop amp come from?You tube shows a trainwreck meets dumble video.Wow!!!!
