80s 1960A speakermounting bolts: size & type?
  • 80s 1960A speakermounting bolts: size & type?
    Hi all
    I'm missing the 16 bolts for speakermounting from an 80s Marshall 1960A cabinet.
    What type and size do I need? It's not metric (larger than M4, too tight for M5).
    Many, many tia!!!
    Chris Winsemius
    www.CMWamps.com
    Vleuten, The Netherlands
    They're probably BA http://www.britishfasteners.com/threads/index.html
    If a M5 bolt will thread in but goes tight after a few turns, my guess is that they're 0BA.
    I've run a M5 tap through 0BA nuts before in an emergency, but that's really not a good idea with speaker T-nuts
