Anyone know who has 7 string single coil bobbins? - I basically need them to size and make my own flatwork. Measurements......
7 string single coils
The DiMarzio used on the Ibanez Universe is just a humbucker bobbin.
Schecter used a more conventional SC design on their 007 model which had 'Duncan Designed' pickups.
Rio Grande offer Tallboys in 7's.
And WSC make a few, including one with a traditional cover. (Do they make the Duncan Designed stuff?)
Can't think of any others off the top of my head.
Duncan has them right here:
http://www.seymourduncan.com/product.../stratocaster/
Once you know the string spacing, you could use a regular 6 string flat as a template. Just extend it longer.
GuitarJonesUSA sells 7 string covers. You can also size the flatwork to the covers.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
GJ sells covers:
http://www.guitarjonesusa.com/catalo...on=show_detail
You may be able to use them for measurements.
Originally posted by David Schwab View PostGuitarJonesUSA sells 7 string covers. You can also size the flatwork to the covers.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
