Hi everybody,
I know how commonly used a bypass capacitor is used arcoss a cathode resistor in a 12ax7 amplifier stage to boost the highs, at a frequency depending on the capacitor/cathode relationship. What I want to do is find a way to boost the lows instead of the highs by allowing ac bass frequencies to bypass the cathode resistor instead of ac high frequencies. Does anybody know how I could do this? I THINK that what I would do would use a vary large bypass cap to allow a boost to all frequencies (including bass), and then put an inductor in series with that cap to limit the amount of highs that can be boosted. would this work? And I was curious what values of inductor would be effective in passing audio-band bass frequencies.
I am basically basing this idea on my assumption that an inductor can be used as a low-pass filter.
Thanks for your thoughts!
Anson
Anson
