Music Man RD 110
  • Music Man RD 110
    Any help appreciated.
    There is lots of useful infomation about Music Man amps at
    http://www.musicmanamps.com/
    An RD 110 from their site is
    Series 50 RD (Single Channel) 1982-84 110RD-50
    Chassis 1650-RD
    Speaker 1-10 Ceramic
    O/P power 50 Watts RMS
    Tubes 12AX7, 2- 6L6GC
    12AX7 used as a limiter, w/Limiter control
    http://www.pacair.com/mmamps/schematics/index.html
    Schematics :-
    Gif (zipped)
    http://www.ernieball.com/mmonline/te...ps/1650-rd.zip
    or
    PDF
    http://www.ernieball.com/mmonline/te...ps/1650-rd.pdf
    Hope thats of some help.
      I found the schematic that has the 12ax7. I believe this was a mid-70's version of the amp. Here it is. Tom
      It's not just an amp, it's an adventure!
        A lot of times the amp is fixed by replacing Q 3 and Q 4.
        Making sure that Q3 Q4 is properly insulated from the chassis. And that these have good heat sink grease applied...
        and that the screws holding Q3 Q4, are nice and tight.
        That is one of the most common failures in this amp.
        Q3 Q4 can easily be replaced with TIP transistors.
        The amp originally had thermo-pad insulators on Q3 Q4.
        I don't like those thermo-pads.
        I would rather use mica insulators, and heat sink grease.
        I think those thermo pads go stale, after so many hours.
        Another common failure is the high voltage coupling caps. Sometimes they short out.
        HUM: 60 cycle hum in this amp
        is frequently cured by grounding the speaker frame with a wire, to the amp chassis.
        Depends on the speaker. Especially if the amp has an EVM speaker...
        The amp (speaker) will even HUM with the standby turned off.
        This is your CLUE that the speaker frame is not grounded.
        I would probably say, that's the most common stuff, in a nut shell, from this nut.
        Once you go over that stuff, it's usually a pretty good amp.
          Thanks SGM....
          My friend has this same amp and will be bringing it by this weekend for a checkup. I think he's having some issues with the Reverb but I will certainly look at the items you mention above.
          Tom
