Go Back   Music Electronics Forum > Amplification > Tubes (Valves)
Old 11-10-2008, 12:55 AM   #1
So I got some 6N1P/ECC88's? what should I do with them?
I thought about a DIY hifi, or maybe I could wire up a converter jack and plug them in my amp-- but I'm not sure that would work... and I only have one amp, and a whole lotta these tubes... Does anyone here want some?
Send me your ideas...
elkym is offline   Reply With Quote
Old 11-10-2008, 06:22 PM   #2
bump
Old 11-10-2008, 06:32 PM   #3
Supporting Member
Steve Conner's Avatar
Sorry, I have a heap of them too, and no idea what to do with them.
__________________
"Transformerless is the way to go", said he, without a hint of irony.
Steve Conner is offline   Reply With Quote
Old 01-03-2009, 01:35 AM   #4
I think they are a medium mu twin triode, like maybe a 12AU7 etc.
Look it up on the NJ7P tube database site as an ECC88.
pila is offline   Reply With Quote
Old 09-28-2009, 07:47 PM   #5
Thumbs up
I think ECC88 equivalent 6N1P-EV
Model: 6N1P-EV
Type: Double Triode
Equivalent: 6DJ8, E88CC, 6922
like this, if interesting look here 6N1P-EV | 6DJ8 | ECC88 | 6922 | Double Triode Tube, there are some detailed description about this.
__________________
Interesting Information about Pentode, Double Triode, Nixie tubes and etc. Follow me on http://www.TWITTER.com/UssrTradeCom
UssrTradeCom is offline   Reply With Quote
Old 10-02-2009, 10:44 PM   #6
those are fine tubes to build a cascode preamp stage
drfovan is offline   Reply With Quote
Old 10-21-2009, 07:29 PM   #7
Alf
Are there any schematics floating around using these tubes ?
Alf
Alf is offline   Reply With Quote
Old 10-22-2009, 12:40 AM   #9
I built a cascode front end with a 6dj8/ecc88 the other week- sounded great for dirty/midrangy sounds, never really cleaned up. I'd imagine a little different tone stack with less mids would have helped. I think the cascode sounded pretty awesome and I've recieved complements on other cascode builds in the past.
jamie
imaradiostar is offline   Reply With Quote
Old 10-22-2009, 03:50 PM   #10
Alf
Code:
yeah that's what I thought , will it clean up especially with a humbuckers ?
My main guitar is a Les Paul.
So good for a crunch or lead channel but not for clean sounds .
I think it has to do with the very high transconductance 12,500 microohmos ( is this right ?) I always use mA/V ( 12,5)
I have used tubes with 6,1 ma/V (6,100 mho) ( 6aq8) and they cleaned up only barely and there was a more sudden breakup.
That's why the 12ax7 type of tube sounds so good because of the smooth transition into distortion imho.
Alf
Old 10-23-2009, 12:26 AM   #11
To me the reason for going with a cascode would be achieving a somewhat pentode like sound without using a pentode. You can set up the cascode for slightly less gain and use a tone stack that lends to a "cleaner" sound like a blackface fender or the like. If you have really hot pickups in your les paul I just don't know of any circuit that'll make it sound like a pretty sparkly strat into a blackface Fender.
Maybe you could just try a few circuits. I like the "midrange" control as used by gibson on some of their old amps. It's been revived on a few more modern amps as well. It yields bass or treble rollof at the extreme settings and a nice scooped mid sort of tone in the middle. It's worth trying that into a LTPI for a simple amp with two knobs. I know that sounds like a terrible idea but don't knock it until you've tried it!
I haven't tried it but I intend to shortly.
jamie
6N1P Triode. Anyone Familiar? bob p Tubes (Valves) 9 09-28-2009 07:36 PM
