Go Back   Music Electronics Forum > Amplification > Other Amps
Old 11-10-2008, 04:52 PM   #1
suggestions for non UL stereo tube amp idea
I have a pair of largish 50 watt output tf's, around 4k:2/4/8 ohms. They're new sensor NSC018343 transformers from a project I built long ago. They're larger and heavier than a twin reverb output transformer so I thought they might make a nice stereo amp for monitor speakers in the garage or even running a wedge if needed. I was thinking two 6550's or EL34's per side should make at least 60 watts per channel without having terrible bass response. I would use a toroidal power tf from antekinc.com...amazing prices for some stout power!
Here's the kicker- I don't know the first thing about tube hifi amps and all the schematics I look at tend to favor Ultralinear output sections. I was thinking I could build something with a triode/pentode switch for hi-fi and sound reinforcement usage respectively.
Any recommendations for a circuit to try?
jamie
imaradiostar is offline   Reply With Quote
Old 11-11-2008, 12:12 PM   #2
Supporting Member
Steve Conner's Avatar
Hi Jamie
I believe hi-fi amps are much the same as instrument amps, you can just bolt the output stage of one onto the driver bits of another.
There were basically three hi-fi driver circuits: the Williamson, the Dynaco Stereo 70 and the Mullard 5-20. So just pick your favourite. (If you have trouble deciding, mine is the Williamson.)
The only trouble you might come across when mixing and matching is instability, since hi-fi amps used quite a lot of negative feedback, and your output stage and OT will have different gain and phase shift than the one the driver was designed for: maybe different enough to upset the feedback loop. In particular a pentode or tetrode output stage will have more gain and more LF phase shift than a UL or triode.
You can't just get rid of the NFB, because any speakers you buy nowadays are designed around solid-state amps with high damping factor, and a tube amp with no NFB has a lousy damping factor that will give you a different bass response than the speaker designer intended. (Usually different as in terrible.)
Steve Conner is online now   Reply With Quote
Building a Guitar Amp Out of an Old PA Head - It Seemed Like a Good Idea... bob p Conversions 20 01-23-2010 07:32 PM
Peavey M-7000 stereo amp baddog Music Electronics 3 06-24-2008 01:03 AM
Tube through a SS effect loop amp,suggestions? Le Basseur Music Electronics 8 03-09-2008 08:33 AM
Any suggestions on what to do with an extra tube? Lizard King Mods & Tweeks 8 12-29-2007 11:34 AM
Need suggestions for 50's tube amp debug vortex Repair and Restoration 3 12-14-2006 10:07 PM
