Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 11-10-2008, 10:32 PM   #1
Learning LT Spice
I've finally downloaded this program. I think I tried playing round w/ it once and got a headache... I did not know where to start. Could someone suggest some things to do w/ this program to get familiar w/ what it can do for me. I generally fix tube amps but have fixed some ss amps and would like to be good at both. If there's a good tutorial somewhere I'd like to try that, can't find one in the help menu. Otherwise maybe I should simulate a power supply for a push-pull Class AB circuit? Anyone to steer me in the right direction...
I am currently working on a Blues Deluxe and do not know what a specific voltage should be... was told LTSpice could simulate it and tell me... hence why I've downloaded it and am giving it another go.
lowell is offline   Reply With Quote
Old 11-11-2008, 03:33 AM   #2
Lifetime Member
The search engine is your friend...
User's guide:
http://ltspice.linear.com/software/scad3.pdf
Getting started guide:
http://www.linear.com/designtools/so...artedGuide.pdf
Demo circuit collection:
http://www.linear.com/designtools/so...o_circuits.jsp
LT spice guide:
http://kom.aau.dk/~hmi/Teaching/LTsp...pice_guide.pdf
Beginner's guide to LT Spice:
http://pages.suddenlink.net/wa5bdu/ltguide.pdf
LT Spice introduction:
http://www.uwm.edu/Course/ee301/LTSpice.pdf
LT Spice instructions and support files:
http://highered.mcgraw-hill.com/site...ort_files.html
LT Spice tutorial:
http://denethor.wlu.ca/ltspice/
Basic guide to LT Spice:
http://www.itee.uq.edu.au/~elec4400/...LT%20SPICE.pdf
raiken is offline   Reply With Quote
Old 11-12-2008, 02:31 AM   #3
well that should do.... thanks!
Old 11-12-2008, 10:59 AM   #4
Lowell,
Please find attached simulation for channel switching in Fender Blues Deluxe - I think you are talking about it . Unzip the files to any folder, open the *.asc file in LTSpice and click Run icon (in the toolbar). In order to see Average and RMS signal values you have to left-click(+ hold down the Ctrl key) on V(tp30) label on the graph - you will see a meassage box with values.
If you connect D5 and D6 diodes, you will see that the voltage drops down to 2.5 mV. The next stage (not shown on the simulation) compares 0.6V with 2.4V (or 2.5 mV) and switches channels of the amp.
On the LTSpice group Web site: http://tech.groups.yahoo.com/group/L...ec=group&slk=1 there a complete Fender tube amp simplated. Please check it.
Mark
MarkusBass is offline   Reply With Quote
Old 11-17-2008, 10:42 PM   #5
Markus,
thank you very much for that. that helps for sure. do you use this for tube simulation too?
Old 11-18-2008, 08:29 AM   #6
I'm not that much in tubes amps so the answer is no. But on LTSpice site: http://tech.groups.yahoo.com/group/LTspice/ in the Files section there is a complete simulation of one of Fender tube amps (Bandmaster if I remember correctly). You can search for the simulation and see how it is done. And yes, LTSpice can be used for tube amps simulation .
Mark
Old 11-20-2008, 01:22 AM   #7
cool thanks!
Old 11-21-2008, 07:16 AM   #8
Tonight, the Santa Clara Valley Chapter of the IEEE Power Electronics Society hosted Mike Engelhardt, the man at Linear Technology Corp. that brought you and continues to bring you LTSpice.
You gotta see this guy if you can. He goes around occasionally training groups to use the tool. He got a physics background, and started simulating all kinds of things on computers, back when computers were primal.
Meanwhile, in Berkeley, around 1970, some guys developed CANCER, Computer Analysis of Non-linear Circuits Excluding Radiation. Big man in the EE department got Larry Nagel to come up with a better name. He packaged it as SPICE, Simulation Program with Integrated Circuit Emphasis, and wrote a manual that spilled the beans on the heart of the algorithm used by the program.
So Mike cames along, looking for books on non-linear simulation, and he found Larry's manual. He started writing a simulator for electronics, and Linear Tech hired him to re-do SwitcherCAD, which wasn't very good. He finished the first SPICE-based SwitcherCAD, and Linear started delivering it to customers along with accurate models of their huge library of regulators (now up to 1000 LT models, and all start up accurately). They wanted to sell regulators, not software, and the .com thing was heating up, so they opted to give it away.
Being free, it's much cheaper than HSPICE or PSPICE, two programs that I haven't even purchased at work because they're so pricey for the little use I'd give them. The thing is, its faster, it's more accurate, it's the only multi-threaded SPICE implementation, it's easier to use...
It's really good SPICE. It's had 1,100.000 downloads. That means that Linear gives away more SPICE in a day than Cadence ships in a year.
Lowell - Stick with it. It's really easy to use. Here's incentive -- you can send your output to a file, and you can make that file a .wav.
Imagine simulating a negative bias generator driven off a HV secondary line, making sure that it comes up before the screen voltage, then printing the schematic.
BackwardsBoB is offline   Reply With Quote
Old 11-21-2008, 10:53 AM   #9
Supporting Member
Steve Conner's Avatar
+1, we actually used LTSpice for all our simulation needs at my last job, because we didn't really do that much, and we were too tight to pay for Microsim/Cadence/whatever abortion.
Personally, I think any computer simulation is overkill for tube circuits. Part of the charm of tubes, for me at least, is that they're a simple technology. I've yet to come across a tube circuit that I couldn't get working with a copy of RDH4 and a few different sized mallets. However, I'll admit that I've used simulation when working with hybrid amps.
__________________
"Transformerless is the way to go", said he, without a hint of irony.
Steve Conner is offline   Reply With Quote
Old 11-21-2008, 11:11 AM   #10
The difficulty may be related to problems with proper simulation of output transformers in valve amps. Here is a link to Fender Bandmaster simulation:
http://tech.groups.yahoo.com/group/L...Examples/Apps/ (search for Fender5E7Bndmstr.asc file).
Lowell, it is possible that you may be required to sign up to the LTSpice group if you want to download this simulation (I'm not sure whether it's required).
Mark
Advice for learning jeremymiller Maintenance, Troubleshooting & Repair 6 10-02-2008 02:01 AM
how to start learning amp repair have some nolage fatcatsambo Theory & Design 3 04-18-2008 03:23 AM
Tube Cad / Spice Questions bob p Tubes (Valves) 11 08-31-2007 07:15 PM
Spice model for OT? Andrei_T Theory & Design 0 12-29-2006 05:07 PM
