Go Back   Music Electronics Forum > Amplification > Tubes (Valves)
Old 11-23-2008, 10:28 AM   #1
6bl8/ecf80 for gain stages
i got some 6bl8 triode/pentode tubes the other day. seem like great tubes to use when you want a pentode with a triode in there, which is something im pretty interested in. because they were designed originally for tv tuners, the datasheets dont give the details for using the triode or pentode for voltage gain.
i have found a schematic for an amp (playmaster 116, http://ozvalveamps.elands.com/playma...aymast_116.jpg ) that uses the triode as a split load PI, and the pentode section for voltage gain. im not sure if the pentode is wired for higher gain, or wether it is wired for less gain as not as much is neccesary due to its location in the circuit (just before the PI). it's circuit also incorperates the -ve feedback, which would effect the gain.
does anyone know of any other circuits using these tubes for audio? any ideas as to how suitable the values for the pentode section of the playmaster are for the first tube in a design? im thinking that i would assume the triode is a 12au7 triode, as it has similar gain and somewhat similar transconductance. i have little idea as to wether this is a good idea or not. any pentodes that would be pretty similar to the pentode section, or some tips on how to examine datasheets to find out how similar they are. would using a circuit similar to an ef86 be a good startingpoint for modifying?
i have 6 of the tubes, so im happy to do a bit of experementing at the expense of 1 or 2 of them if neccesary, but i think i need a bit of guidance as i've never done much experementing with amps other than coupling cap values and cathode resistors/bypass caps. have to start somewhere though.
edit: heres a datasheet http://www.pmillett.com/tubedata/HB-...art_1/6BL8.PDF
black_labb is offline   Reply With Quote
Old 02-10-2009, 03:42 AM   #2
Sansui used this tube in their front ends back in the 60's. Google Sansui 500A schematic and you will find a free download. Excellent tube.
cleantimestream is offline   Reply With Quote
Old 02-10-2009, 05:54 AM   #3
Quote:
finished the amp and am very happy with the 6bl8, but will deffinately check it out as i plan on using it for my next amp as well. thanks for the tip
gain differences in driver/PI stages for cathodyne, paraphrase, long tail pair tubeswell Tweed Builders 7 03-04-2010 04:33 AM
Gain Stages and High Pass Filters shef86 Theory & Design 0 07-01-2008 07:50 PM
desigining gain stages for... EETStudent Theory & Design 6 06-06-2008 06:36 PM
low gain on ef86 gain stage problem black_labb Maintenance, Troubleshooting & Repair 4 02-17-2008 06:01 PM
Fewest gain stages..... dave251 Theory & Design 10 06-28-2007 05:22 PM
