Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 10-28-2006, 12:54 AM   #1
Question VU Meter
I was just wondering if anyone has any thoughts about incorporating a VU meter into a guitar amp. Does it hurt the tone? I found a really cool looking meter, and I want to use it for eye candy on a practice amp that I'm building for myself. I was thinking about putting it on (near?) the grid of the last preamp stage. I want to adjust 0dB for the bias voltage to indicate where it will clip. It comes with an external resistor, so I assume it's adjustable. Although, I've never used one. Thanks in advance for any ideas. Yossarian.
Yossarian is offline   Reply With Quote
Old 10-28-2006, 01:23 AM   #2
Supporting Member
Steve Conner's Avatar
The signals in a tube preamp probably don't have enough current to drive a pointer-type meter. When I added a meter to my amp, I connected it across a 1 ohm cathode resistor common to both power tubes, so it read more or less the current drawn by the power tubes. The needle sits at about 30% when idle and starts to flap around if I play loud. If it slams off the end stop I know I'm probably playing too loud or have the wrong speaker impedance.
It's also handy for biasing when installing new power tubes, and getting an idea of whether your old ones are worn out. If they can't kick the needle as far as they used to, it could be time for the scrap heap (or the bottle bank? ) So I say it's not just eye candy.
Steve Conner is offline   Reply With Quote
Old 03-19-2008, 04:17 PM   #3
NOS Sunn VU Meters
I have a handful of NOS VU meters from the Old Sunn Headquarters in Williamstown Kentucky. Any Interest?
Terry
fluhome is offline   Reply With Quote
Old 03-19-2008, 04:39 PM   #4
Supporting Member
Maybe, what size are they?
steve
__________________
"Transformerless is the way to go", said he, without a hint of irony.
gauss meter... How much do I need to spend? corduroyew Pickup Makers 18 11-14-2006 12:17 PM
Extech meter mods? ken Pickup Makers 4 09-08-2006 05:21 AM
