| Music Electronics General discussion about music electronics |
| | #1 |
| Junior Member Join Date: May 2008
| Marshall Plate Voltage Schematic Mystery
Im working on a Marshall 9005 pwr amp. Schem attached. I have two versions of this amp. One shows R21 as a 39k the other shows R21 as a 10k. What difference would this value make in this amp? obviously its changing B+ on the PI. Any ideas?
| | #2 |
| | #3 |
Look in the lower right corner of the drawing you linked. In the notes, it says that resistor was changed from 10k in 1990. Ohms law tells you that at 39k, it will drop more voltage than at 10k. Looks to me like they decided the preamp voltages were too high. |
| | #4 |
Yes i did notice that.... i was just wondering what effect .. at least in theory... lowering this voltage would do.... i cant remember if raising B+ on the PI plates increases gain or decreases... i also know it has some kind of efect on frew response i believe...
| | #5 |
| Senior Member Join Date: Oct 2007 Location: Tucson, AZ
...higher voltage equates to: A) more voltage available to develop voltage-swing over, and thus more gain POSSIBLE but not guaranteed. B) higher fequency response POSSIBLE, due to lower plate loading.
__________________ ...and the Devil said: "...yes, but it's a DRY heat!" |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Marshall JTM30 mystery | scr@tchy | Maintenance, Troubleshooting & Repair | 18 | 11-08-2008 05:09 AM |
| EL84 Plate Voltage | grandmasterflash213 | Theory & Design | 4 | 05-31-2008 10:47 AM |
| Plate voltage w/ tubes in | lowell | Maintenance, Troubleshooting & Repair | 3 | 05-08-2008 03:59 AM |
| Marshall Major plate voltage | Doug | Maintenance, Troubleshooting & Repair | 2 | 09-27-2007 06:53 PM |
| relationship between high voltage supply and plate voltage | studioit | Theory & Design | 10 | 06-06-2007 12:22 PM |
