Results 1 to 15 of 15
Thread: 7189A sub?
    Apr 2008
    Oceanside, NY
    1,644
    7189A sub?
    Anyone have a viable sub for this rare bird? In lower-voltage applications, EL84's can be used, but we are talking about 400V here. 7189A was essentially a beefier version of the 6BQ5/EL84. FYI- I am restoring a Magnatone M10A. Of course, I can always do NOS, but these are getting a bit pricey. There are 4 on eBay BIN at $129.00. That's the cheapest I've found.
    John R. Frondelli
    "Mediocre is the new 'Good' "
    Senior Member Garydean's Avatar
    Sep 2007
    Indialantic, Florida
    344
    Hi John,
    Have you considered an E84L? It's rated higher than an EL84. If your screen voltage is under 300 you'll be fine. Prices are all over the map but you may be able to get a pair for under $50
    E84L specs.
    13.5 watts max plate dissipation with 450V max plate volts. Slightly higher specs than a 7189A.
    Gary
    Apr 2008
    Oceanside, NY
    1,644
    It won't work. The screen voltage is up around 390V and it's a UL-tapped transformer, BUT in a cathode-bias scheme. Not yer everyday circuit design or tube requirement, for sure.
    John R. Frondelli
    Supporting Member Steve A.'s Avatar
    1,407
    Quote Originally Posted by jrfrond View Post
    FWIW the Peavey Classic 50 has something like 392 volts going to the plates of four EL84's and I don't believe that amp is known for trashing output tubes. As I recall the screens are a few volts lower than that.
    I know that exceeds the specs of EL84's but it doesn't seem to cause any problems. (Or does it? I dunno)
    Steve Ahola
    Sep 2007
    344
    The internal pin connections on the 7189A are unique so even if there is a direct replacement voltage wise, it still may not work.
    try here
    http://www.tubedepot.com/nos-7189a.html
    Senior Member hasserl's Avatar
    978
    Quote Originally Posted by Steve A. View Post
    Steve Ahola
    And the Carvin Nomad and BelAir amps run EL84's in the 390 and even low 400's, with the screens ~ 6 - 8 volts below the plates. The tubes run fine at those voltages. I've got a Nomad that I've had no tube failure issues with at all. And I've seen dozens of these amps, as I do a lot of Carvin amp mods, with the original tubes in them with years of service on them, still running just fine.
  7. #7
    Apr 2008
    Oceanside, NY
    1,644
    The amp is PTP, so I am not concerned about rewiring the sockets. However, it MUST be reliable, and it is for a big-name client, so I think I will just go NOS. I'm not stoked by the quality of current EL84's from any manufacturer. I've just seen too many fail.
    John R. Frondelli
  8. #8
    Supporting Member tubeswell's Avatar
    Feb 2007
    Wellington NZ
    3,774
    Blog Entries
    1
    What about EL84Ms? (I think they can handle about 400V)
  9. #9
    May 2007
    pacific north west
    5,893
    Quote Originally Posted by Garydean View Post
    You just need to rewire so the "unused" pin sockets are not used. Then any el84/6bq5/7189 tube will "function" in the socket. Not too far to go when retrofitting an amp that used obsolete tubes. FWIW I mean obsolete in the sense that they are not made anymore, not that they aren't good tubes.
    Many amps run the plates of el84 tubes at 400 volts and the screens a bit lower. These ARE guitar amps and not "hi fi". But the tubes will live, even if they are creating more THD than a stereo could accept. I personally know of a Messy Booger amp with 398vp and 385 on the screens that still sounds good after 2 years using old Sovtek tubes. Some Traynor amps will put 420+ vp on el84s with modern wall voltages and yet they survive. I think if you pay attention to the bias limitations and buy good tubes that you'll be fine. Rewire the amp for el84's. What else is going to be plugged into it from this date foreward?
    Chuck
  10. #10
    Dec 2007
    769
    How many 7189A tubes do you need?
    I have one NOS Westinghouse.
  11. #11
    Dec 2008
    Baltimore, MD
    4
    Quote Originally Posted by Diablo View Post
    Don't know if you got your tubes yet. Have you considered the Soviet Military surplus (USSR) tube 6П14П -ЕВ? While they are drying up quickly, they are an excellent replacement and usually sell for about $11 each. Many places have them.
    JMHO...
  12. #12
    Apr 2008
    255
    I thought 6p14p-ev was a 7189A sub, but I'm not sure...no russian data sheets around.
  13. #13
    Dec 2008
    Baltimore, MD
    4
    Quote Originally Posted by 6267 View Post
    Yes! That is exactly what it is. Very good tubes, priced right.
  14. #14
    Dec 2008
    Baltimore, MD
    4
    Try this page. It is the tube pinout:
    http://translate.google.com/translat...%3Den%26sa%3DG
  15. #15
    Supporting Member
    Jun 2008
    Italy
    1,139
    I admit it's not as thorough and complete as an old datasheet, but check this out...
    http://www.tubes.ru/techinfo/HiFiAudio/6p14p.html
    BTW I used some of these russian mil-spec tubes and they're very good value for the money, and they're a little bit beefier than 7189s and E84L too.
    Best regards
    Bob
