| | #1 |
| Junior Member Join Date: Nov 2008
| Capacitor Temperature ratings
I'd like to replace the multi cap in a PR with a 30/20/20/20 but it only has a 55C rating, the stock 20/20/20/20 is 85C. Will a 55C cause problems since it is so close to the power tubes?
| | #2 |
| Member Join Date: Aug 2008 Location: michigan
I used a 40-20-20-20 in mine. Anyway, it's just under 2 inches away from the power tubes, and I really doubt if it will absorb too much heat.
| | #3 | |
| Lifetime Member Join Date: May 2006
| Quote:
The temp rating on a cap is a statement about working life at that temperature. The maker warrants X power on hours when used at the rated temperature. This is usually based on the electrolyte material and where it begins to degrade. There is not only the standard lifetime-halves-per-10C-rise, but there is some temp where the electrolyte chemically degrades producing a fall off the cliff. If you can get an 85 C part that is far more advisable. But if you CAN'T get an 85 C part, use the 55C as a stand in so you can use the amp while you find the perfect cap. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Capacitor Temperature ratings | ncboy654 | Maintenance, Troubleshooting & Repair | 0 | 11-24-2008 10:21 PM |
| trying not to exceed 6X4 ratings | EETStudent | Theory & Design | 6 | 05-16-2008 06:53 PM |
| tube ratings? | samgomez141 | Tubes (Valves) | 2 | 04-03-2008 06:03 AM |
| wire ratings | MitchK | Theory & Design | 4 | 12-20-2006 02:32 AM |
| Tube temperature | tonezoneonline | Maintenance, Troubleshooting & Repair | 6 | 08-28-2006 05:12 PM |
