Old 11-27-2008, 01:28 PM   #1
peavey bandit 112 cutting out
Hi,
I have a Peavey bandit 112 which after a period of time at rehearsal will start to cut out. The sound cuts in and out at varying rates and between an attenuated volume and the volume I have set. Over the years I've used switch cleaner in all the 1/4" sockets and all the pots which seemed to do the job. I have now bought another amp and left this one gathering dust. I recently fired it up and noticed when I tapped the pre and post gain I can hear the tap through the amp. Also some interference when I touch the casing of the pot. Could it be the Pots need replacing?
Any advice gratefully received.
Thanks.
HarryLime is offline   Reply With Quote
Old 11-27-2008, 02:38 PM   #2
First, if the amp has an effects loop, plug a spare cord directly from send to return. If that helps, replace the return jack or service it. Likewise test if ther is a pair of jacks marked preamp out and power amp in.
If that doesn;t help. pull the board and resolder all the controls. And jacks.
Is there a headphones jack with a speaker cutout? Check that.
And if that doesn;t work, apply a signal, connect the chassis to a speaker and start poking with a chopstick, looking for anything that responds to motion.
__________________
Old 11-27-2008, 04:46 PM   #3
Yes in the past I have plugged a spare cord through send and return, also with Preamp and poweramp. which on a few occasions did the job. The last rehearsal I did this had no effect. I'll have a go at resoldering the controls and jacks.
No there is no headphone jack
Thanks.
Old 11-29-2008, 02:40 AM   #4
You can also, once this happens, plug the guitar into the power amp jack or the effects return jack. Does that also sound weaker than normal? Try it while working OK as a benchmark. This breaks the amp into sections to localize the fault.
__________________
Old 10-27-2009, 07:14 AM   #5
Harry,
Did re-soldering the controls and jacks fix the problem? I am having the same problem with my bandit which is about 6 years old now. I have tried plugging a spare lead into the effects loop, but as you said it only works some of the time.
I am a little hesitant to start re-soldering everything without knowing it will fix the problem.
geoff is offline   Reply With Quote
Old 10-27-2009, 08:40 AM   #6
If a cord plugged from send to return on the FX loop jacks doesn;t cure the problem, then those jacks are probably not at fault. How about the preamp out and power amp in jack pair, did you do the same test there? Either pair of jacks can cause this - or both for that matter.
I would certainly have the board out and resoldering the controls and jacks at this point.
I would be flexing the board and pushing each component with an insulated probe - a wooden chopstick works fine - looking for a sign of an intermittant connection.
Beyond that, you are applying a test signal at the input jack and following it through the amp looking for where it is interrupted.
__________________
Old 10-28-2009, 03:29 PM   #7
Quote:
Originally Posted by geoff View Post
Harry,
Hi Geoff,
No I didn't get around to trying this out. I have a different amp now, my friend needed one so I gave him the Bandit for nothing and explained the issue with it. It was a good old trusty amp that kept me going for years. Good luck sorting your problem out.
Harry
Old 10-31-2009, 07:00 AM   #8
Thank you Enzo, I tried plugging a spare lead to the pre amp out and power amp in. I've been playing it for a couple of days since doing so and it seams that this has solved my problem!!
Old 10-31-2009, 08:24 AM   #9
It will not hurt the amp in any way to run this way as long as you like. However, since that cured it, that means the power amp in jack has an issue.
Squirt some cleaner into that jack then probe a plug in and out a few times. Now see if that woke it up. Otherwise the trouble is either the jack is bad or the solder under the jack has failed.
__________________
Tags
112, bandit, peavey, pot, potentiometer
Peavey Bandit 112 Transtube - Dodgy pots? black_box Maintenance, Troubleshooting & Repair 9 10-12-2009 01:57 PM
My peavey bandit works rather weird butters Maintenance, Troubleshooting & Repair 3 10-11-2008 02:41 PM
Peavey Bandit 112 low volume porman Maintenance, Troubleshooting & Repair 2 05-30-2008 08:36 AM
Peavey Bandit Reverb Issue fxcarden Maintenance, Troubleshooting & Repair 2 04-16-2008 07:05 PM
bandit 112 problem JC@ Maintenance, Troubleshooting & Repair 7 07-04-2007 08:32 PM
