Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 11-28-2008, 04:34 PM   #1
Adding drive to bass amp?
Hi,
I'd like to add some drive to an existing bass amp. Currently the preamp is a Fender like configuration - triode - tone stack - triode. Is it a good idea to add one more tube /first triode will be common/ and build a drive section /LF cut at 500-800Hz for example/ for the drive sound which will be mixed with the clean bass sound?
Any other ideas and comments will be appreciated.
GainFreak is offline   Reply With Quote
Old 11-28-2008, 04:47 PM   #2
The first thing I'd have to question here is: why you would LPF the signal chain anywhere in a bass amp at 500-800Hz?
You just need gain to overdrive the first input stage. What I see in my head is an DRIVE switch that does three things: 1) switches pre and post-drive stage to enable drive, 2) attenuates the signal post-preamp (perhaps engaging a MV control) to maintain output level, and 3) engages a post-2nd stage LPF filter (fixed or variable one-knob control) to smooth-out the tone.
__________________
John R. Frondelli
jrfrond is offline   Reply With Quote
Old 11-28-2008, 06:17 PM   #3
This is how it's usually done in a bass drive pedal although I'm not sure about the LF frequency.
help adding 'preamp in' to existing amp... HTH Theory & Design 12 10-08-2008 12:24 PM
adding a true bypass switch to a 7 watt amp randomair Music Electronics 1 07-22-2008 05:16 PM
Hartke HA-3500 Troubleshooting - Bass Amp Crackles & Pops davidm Maintenance, Troubleshooting & Repair 2 05-07-2008 11:17 PM
Adding an OT and tubes to make amp stereo Guitarist Mods & Tweeks 1 01-18-2008 12:10 AM
Mini amp to drive talk box Neal Guitar Effects 8 08-19-2006 03:47 AM
