| | #1 |
| Junior Member Join Date: Dec 2008
| Harmonics sound on 12th fret of my Strat
Somebody please help Me. when I play on my 12th fret i get a dual tone. I keep playing with My truss rod adjustment to no avail. I changed the string and that didn't help. Does anyone know what My problem is?
| | #2 |
| Member Join Date: Nov 2007
Sounds like wolf tones to me, this occurs when your single coil pickups are to close to your strings. I used to play strats in a club band and ran into that after adjusting my pickups closer to the strings and then found out that I had to lower the pickups away from the strings to fix this. The magnetic pull from your pickups cause wolftones (wable tone at the 12th fret)) if they are too close. Maybe some one else can chime in as that is the only thing I can think of. Hope this helps. Dave |
| | #3 | |
| Senior Member Join Date: Jan 2008
| Quote:
| | #4 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
Yes, especially on under the lower strings. You need to angle them lower on the bass side than the treble side. This is commonly known as "Stratitus". The magnets are pulling the strings out of tune.
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab |
| | #5 |
| Junior Member Join Date: Dec 2008 Location: USA
| magnetic fields
I agree with Dave N on this, the magnetic field of the pick up can cause changes in the ellipictal movement of the strings. this is even more so with the bass strings due to the lower sound frequency and slower vibration rate. This can give false tones. Also have you set the innotation of the strings, changes in truss rod adjustmets and string gauge can cause the tone to sound off. Set your neck and string hight to your preferance and set the innotation, while doing this lower the pick ups all the way down to avoid magnetic influance on the strings. Once set raise them one at time, deepress both E strings at the last fret and set the pick up 1/8th inch from the string.Hope this helps.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Stainless fret wire | Chuck H | Guitar Tech | 17 | 07-20-2008 07:00 AM |
| Preserving even order harmonics in push-pull | bluefoxicy | Theory & Design | 11 | 06-13-2008 06:11 PM |
| Fret buzz? | gibsonaxe | Guitar Tech | 4 | 04-07-2008 04:57 AM |
| Odd Harmonics | chunkitup | Theory & Design | 1 | 08-06-2007 06:01 PM |
| Fret Buzz | peteko | Guitar Tech | 5 | 10-04-2006 01:41 AM |
