| | #1 |
| Junior Member Join Date: Dec 2008
Hi, Iīm having problems with my diy champ (blackface) when I turn up the volume on my amp there is a strange scratchy noise (like a dodgy pot). It canīt be the pot because it is brand new. replaced the old one and when i tested the amp it was all the same as before. the noise is about half way up, and when it comes to the noise "area" the amp looses volume. when turned up from there it is just fine apart from the fact that there is no overdrive. Iīve tried changing the tubes, still the same. tried changing the filter caps and some other caps. measured all the resistors, seems to be fine the lot. whatever I seem to do I canīt get rid of the problem.... (tubes: 12ax7 and 6v6) Any ideas? |
| | #2 | |
| Senior Hollow State Tech Join Date: May 2006 Location: Denver, Colorado
| Quote:
Try moving wires around the 12AX7 grids (lugs 2 and 7) and to and from the volume pot to different angles and locations to see if that effects this issue. If so, you should try shielded audio cable if you have not. | |
| | #3 |
| Senior Member Join Date: Apr 2008
I'd second Amp Kat on the oscillation, as I'm working on getting a pretty high gain design into a cabinet and I get this from time to time. It sounds like someone is crumbling newspapers up rapidly, in my case. It could also be DC on the pot, so you may want to check it with a meter. Pots make scratchy sounds when they have DC on them. Also, some pots are just terrible. I've had some pots where the conductive surface starts flaking off (they were pretty old) and it cause all kinds of crazy problems.
| | #4 |
| Senior Member Join Date: Sep 2006 Location: Englewood, CO
Could also be some residual DC on the pots from possibly a leaky coupling cap or such. It only takes a few milivolts to make the pot scratchy. If the pot came right off one of the tubes, a leaky tube can put some voltage on the pot too, but I'd guess you've replaced all the tubes by now. glen
| | #5 | |
| Quote:
| Bookmarks |
| Tags |
| fender champ, problem, strange |
| Thread Tools | |
| Display Modes | |
| First Build, 5E3, strange problem, help please | cfidave | 5 E 3 | 37 | 12-22-2008 04:52 PM |
| Strange power section problem | EETStudent | Maintenance, Troubleshooting & Repair | 7 | 06-20-2008 10:49 AM |
| marshall JCM 800 Bass series strange problem | adaramit | Maintenance, Troubleshooting & Repair | 1 | 03-18-2008 07:02 PM |
| Champ kit: arcing problem | vega | Debugging Your Build | 2 | 08-05-2007 06:02 PM |
| Strange Buzzing problem | Gordon303 | Maintenance, Troubleshooting & Repair | 4 | 05-31-2007 02:41 AM |
