Old 12-28-2008, 05:44 PM   #1
needing circuit board repair wire???
Hi group I am working on my TSL that fried a small cap and took the pad with it and I believe the barrell. I used to use a very thin wire to help repair situations like this. Luckily the pad side that got toasted is just the pad and not attached to anything.
Does any one know where I can buy this type of wire and what guage I would order???? I will be running it through the barrell along with the cap leads.
Thank you for any feedback.
wyomingrocks is offline   Reply With Quote
Old 12-28-2008, 06:18 PM   #2
28 or 30AWG wire-wrap wire, stripped, works well if you have to get through a via. Pretty much any fine solid-core (non-stranded) wire can do the job - even a length of component lead, like that replacement cap's.
Hope this helps!
Don Moose is offline   Reply With Quote
Old 12-28-2008, 06:44 PM   #3
thanks
Ya, that helps alot. Thanks again
Old 12-29-2008, 01:58 AM   #4
I use buss wire, like the stuff AES (tubesandmore.com) sells. It comes in a roll, and it's handy for grounding across the backs of pots etc.
pila is offline   Reply With Quote
Old 12-29-2008, 11:27 PM   #5
For signal lines, wire-wrap works fine, but you cannot use it on an power or ground busses. For this, you need to use a larger gauge (22 or 24AWG) buss wire.
__________________
John R. Frondelli
jrfrond is offline   Reply With Quote
Old 12-30-2008, 02:50 AM   #6
And if this cap is the one on the end power tube between pins 3 and 4, when those pads go, I just solder the new cap right to the socket pins.
__________________
Circuit Board issue!!!!! lordnikon Maintenance, Troubleshooting & Repair 4 04-18-2008 11:15 PM
Corrosion on circuit board Neal Music Electronics 0 03-31-2008 03:53 PM
turret board vs eyelet board clintonb Build Your Amp 5 09-22-2007 08:44 PM
peavey classic 50/410 burnt circuit board pbdog Maintenance, Troubleshooting & Repair 5 09-19-2007 01:17 PM
newbie needing enlightenment jonson Pickup Makers 6 04-20-2007 08:53 PM
