Go Back   Music Electronics Forum > Amplification > Guitar Amps
Guitar Amps General discussion about amps
Old 12-31-2008, 10:37 PM   #1
Transformer load question
Is it safe to run a 8 ohm load on my bassman that has a 4 transformer?
Thanks
baddog
baddog is offline   Reply With Quote
Old 01-01-2009, 09:38 AM   #2
It should be. You will lose power. Most amps will accept a 1/2 or 2x load without failure. I do it all the time. Some players do it because they prefere the tone. But...
There are alot of different "Bassman" amps. Some may be more finiky than others. I don't know enough about all the different Bassmans to be 100% sure.
Chuck
Chuck H is offline   Reply With Quote
Old 01-01-2009, 06:44 PM   #3
dhuber's Avatar
I've done it and I would say yes. Putting a higher resistance on a amp should not hurt it. Putting a lower resistance on an amp would increase the load on the amp and I would think that could cause stress on the output transformer and output tubes.
__________________
Crate V33h, Peavey Classic 30h & 100h, Traynor YCV20WR
dhuber is offline   Reply With Quote
Old 01-01-2009, 07:51 PM   #4
Actually it's the other way around. Running an amp into too high an impedance or an open load can cause arcing in the OT. Too low an impedance or a short will be harder on the tubes but won't generally harm the OT. Most PA failures caused by impedance mismatch are due to too high an impedance or an open load, not too low an impedance or a short. In fact, many MFGs use a shorting jack on the speaker output so that if you try to run the amp with no speaker plugged in the amp will be running into a dead short rather than an open load.
Chuck
Old 01-01-2009, 08:05 PM   #5
What he said.
Remember, this is for tube amps. On SS amps, usually there is a minimum load - you can go higher and even open (no load) without damage.
HTH
Albert
Albert Kreuzer is offline   Reply With Quote
Old 01-02-2009, 08:31 AM   #6
Yea, what Albert said too
Chuck
Old 01-02-2009, 11:15 PM   #7
Thanks to all who replied
BAddog
Old 01-06-2009, 01:54 AM   #8
dhuber's Avatar
Chuck,
I stand corrected, Thanks for the clarification!
__________________
transformer question dwhutchens Theory & Design 2 10-22-2008 02:43 AM
Transformer question AkisTzortzis Theory & Design 35 07-25-2008 08:48 AM
Output Transformer Question ajeffcote Maintenance, Troubleshooting & Repair 21 05-18-2008 09:17 PM
Speaker Dummy Load Question Gage2k5 Mods & Tweeks 4 12-01-2007 12:01 AM
Switching circuit load on PT bias tap question Ptron Theory & Design 1 02-02-2007 07:16 PM
