Go Back   Music Electronics Forum > Amplification > Other Amps
Old 01-05-2009, 10:10 PM   #1
Ampeg SVT-4 Pro
This amp cuts off and sound fuzzy after 5-10 minutes of playing. The dealer does not know what it is. I have heard from other music stores that looked at it that it might be the output transistor.
Here's the problem,
I play for a few minutes then as I'm playing the sounds distorts (fuzz) and fades away. I have ran another amp to my 6x10 HLF speakers and it's not the speakers. I have changed cables and it's not the cables, I used a Speakon as well as a monster bass chord. The repair shop just called and said they don't see a problem with it. I told them to play for 5-10 and see what happens. I'm still waiting for there phone call. I'm confused I really need my amp fixed!!! Can you guys help or give me a sense of direction?
Thanks,
Frank
LocoBassPlayer is offline   Reply With Quote
Old 01-08-2009, 11:41 PM   #2
Well thanks for your help. I'm gonna walk out the door. Can someone terminate my account?
Thanks in advance.
Old 01-09-2009, 06:07 AM   #3
Quote:
Thanks in advance.
Sorry, it is hard to say what your amp might need.
__________________
Enzo is online now   Reply With Quote
Old 01-09-2009, 07:27 PM   #4
Garydean's Avatar
I would be looking for a cold or cracked solder joint. They have been known to have that problem. Can't really narrow it down though that symptom could be lots of things. Are you rack mounting it? If so, that can create a heat problem in those units. Testing it out of the enclosed rack problem goes away. There are plenty of components in there that could fail from excessive heat. Which one? We would only be guessing at this time, without taking some voltage readings inside.
Garydean is offline   Reply With Quote
Old 01-09-2009, 09:00 PM   #5
Thumbs up
Quote:
Hey guys,
Thanks for the response and shedding some light. Yes, I do rack mount the amp. The SKB Rack Case comes with Shock Absorbers. I was told by the dealer that they found the problem but has not advised me of it. I think you are correct. Thanks for your help.
Old 01-10-2009, 03:05 AM   #6
ken
ken's Avatar
I have a SVT-4 with the samesymptom. It had a defective driver in the power amp, and I wasn't as lucky as LocoBassPlayer was. I lost the power amp, and now it's basically a big paperweight.
Ken
ken is offline   Reply With Quote
Old 01-12-2009, 10:30 PM   #7
Quote:
Ken
I guess I found my problem here.
http://books.google.com/books?id=a3C...sult#PPA296,M1
Old 01-21-2009, 11:12 PM   #8
Quote:
FYI, they found the problem. "OUTPUT TRANSISTOR"
Old 01-22-2009, 12:49 AM   #9
There are so many different things that can cause trouble in an amp, without looking into it yourself, it is very hard to say what we would find. I am glad your amp has been sorted out.
__________________
Ampeg SVT-5 Pro distortion bnwitt Maintenance, Troubleshooting & Repair 32 02-27-2010 12:35 AM
Schematic for Ampeg SVT 2 pro pbdog Schematic Requests 5 10-07-2009 11:55 PM
AMPEG SVT lll PRO keysnleslie Other Amps 12 05-01-2009 11:18 PM
Ampeg SVT-4 PRO Direct In issiue.. mLascano Maintenance, Troubleshooting & Repair 7 12-20-2008 06:58 PM
Ampeg Svt 4 Pro PrimoCapone Music Electronics 1 07-17-2008 07:39 PM
