| | #1 |
| Junior Member Join Date: Jan 2009
| RockerVerb 50 blowing HT fuses
Blowing fuses with NO POWER TUBES in. Very strange. This happens intermitantly, and when it does the plate voltage drops to around 200 volts. I have replaced the on/off/standby switch. I'm drawing at straws. Any help? Thanks, doylefan |
| | #2 |
Got a schematic? Does the amp have a rectifier tube? That could be the culprit. If not, there is a short circuit somewhere on the PT secondary HV circuit, it could be the power transformer itself. |
| | #3 |
I think so too. Disconnect the center tap wire from the output transformer. Now watch the B+ and see if it still sinks. if not, then the output transformer may well be bad. If the B+ still droops to 200v with the transformer disconnected, you more likely have a failing filter cap or an arc somewhere like a tube socket.
| | #4 |
| Junior Member Join Date: Jun 2008
Schematic is here: http://www.shortscale.org/forum/view...6a24c523219363 |
| | #5 |
thanks guys, i'll try these suggestions now and let you know how I make out.
| | #6 |
I think I tracked it down to C5 (filter), I'll try replacing it. Tough because this is an intermittent problem.
| | #7 |
No luck. seems to be ok when i disconnect the choke. strange because I disconnected the preamp, removed the power tubes, lifted the bias circuit to isolate the problem and it's still there. You can see the fuses arcing inside.
| | #8 |
| Supporting Member Join Date: Mar 2007 Location: in bosky Surrey, England
- just had this same problem. On this amp it was caused by C3 shorting out. I put new fuses on, fired it up on the light bulb and traced it by the smoke I'll put the schematic page on here. So what's C3 for? Last edited by Alex R; 06-12-2009 at 09:57 PM. |
| | #9 |
Transient suppression.
| | #10 |
Thanks Enzo. It looks like an accident waiting to happen sitting there, but (here comes the confession) as I haven't quite fully grasped cap-fed bias I didn't know whether this was some strange permutation of it, so instead of binning it as I was tempted I replaced it with a 1kV. Couldn't read the rating of the little burned blue disk I took out. Maybe it really did get a transient! There to satisfy some safety reg. or other I guess? |
| | #11 |
Or noise.
| | #12 |
| Junior Member Join Date: Sep 2009
sorry to reopen this.. I am having something similar.. Blowing HT fuses constantly. Have umplugged the Choke to confirm the 1st section and the TP6 to completely eliminate the transformers etc. I am coming up with Cap 5? Thoughts?? Is this common? Thanks Janne |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Classic 30 blowing fuses... | HojoMojo | Maintenance, Troubleshooting & Repair | 11 | 06-29-2008 09:12 PM |
| Blowing Fuses | EETStudent | Maintenance, Troubleshooting & Repair | 11 | 05-08-2008 07:10 PM |
| Blowing Fuses.... | Bob M. | Maintenance, Troubleshooting & Repair | 10 | 03-28-2008 07:18 AM |
| Blowing fuses | lowell | Maintenance, Troubleshooting & Repair | 7 | 03-24-2008 01:14 AM |
| Blowing fuses... | riscado | 5 E 3 | 7 | 08-21-2006 04:06 PM |
