Old 01-09-2009, 01:46 AM   #1
Hot Rod Deville 212 -- Blown Fuse
Hey everyone. I just got back from a three week vacation and turned on my amp. As soon as the red light came on the amp popped and turned off. Nothing would power up -- no lights, no sounds, no anything. A fuse was definitely blown (I took it out) and I'm wondering whether I should just replace it myself (3A 250V) or bring my amp to a shop. Is it possible that the fuse just blew on its own and there's no deeper problem (bad tubes or anything like that)? If there is a bigger problem, could replacing my current fuse and blowing the new one make the problem even worse?
The amp is between two and three years old.
Thanks for any input!
Phranklee is offline   Reply With Quote
Old 01-09-2009, 01:50 AM   #2
Garydean's Avatar
Fuses don't blow on their own. Something made it blow. I would check the output tubes first.
Garydean is offline   Reply With Quote
Old 01-09-2009, 02:06 AM   #3
But by all means try another fuse. Most common reason for fuses to blow is a failed power tube.
__________________
Old 01-10-2009, 04:55 PM   #4
izzybell2810's Avatar
Hi there,
I've owned and gigged a Deville for about 12 years now. I replace my power tubes about every six months, which has cured the problem of turning up at a gig, turning on and popping a fuse because a tube is shorted. Take out the power tubes replace the fuse (if your supply voltage is 230 then the fuse is 1.6 amp, 3 amp for 110v) if the amp will come of standby without blowing the fuse then you have a bad tube.
izzybell2810 is offline   Reply With Quote
Tags
blown fuse, hot rod deville 212, repair
Fender Hot Rod Deville Rob Stmple Maintenance, Troubleshooting & Repair 5 11-24-2008 11:51 PM
Hot Rod DeVille 410 issue stevek Maintenance, Troubleshooting & Repair 3 11-21-2008 10:46 PM
Strange Hot Rod Deville breakup billings Maintenance, Troubleshooting & Repair 8 11-20-2008 09:04 PM
Deville Hot Rod 212 fizzled out webzz Maintenance, Troubleshooting & Repair 4 08-12-2008 02:54 AM
Fender hot rod deville UsaGold91 Flea Market 0 04-09-2008 01:47 AM
