| | #1 |
| Junior Member Join Date: Jan 2009
I have a Marshall MG100 HDFX solid state amp, the clean and overdrive work, but the effects including reverb don't. I've tried using a patch cord from effects send out to the return, and it doesn't trigger the effects. I've used the foot pedal on different amps, and it works as well (Which is the only way to turn on/off effects) How do I pin point what chip or component is at fault? Thank You |
| | #2 |
If the amp works but the FX and reverb don't, then it looks like either IC3 is bad or the DFX card is. Make sure there is good +5v to the DFX card as well.
| | #3 |
I appreciate it, thank you for the schematic and info |
| Bookmarks |
| Tags |
| marshall mg100 hdfx |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Dead Marshall MG100 | cpuslave | Maintenance, Troubleshooting & Repair | 28 | 11-17-2009 11:38 PM |
| Marshall hdfx schems? | drewl | Maintenance, Troubleshooting & Repair | 6 | 09-13-2008 12:52 AM |
| Marshall TSL100 Effects loop question | BrotherJ | Mods & Tweeks | 0 | 06-17-2008 11:59 PM |
| Marshall MG100 FX master volume | Teleman55 | Maintenance, Troubleshooting & Repair | 3 | 04-14-2007 02:03 AM |
| Marshall MG100 HDFX Troubleshooting | bloodynoone | Guitar Amps | 3 | 03-14-2007 02:27 PM |
