Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Conversions
Old 01-11-2009, 04:11 PM   #1
Bogen Output transformer
Hello all,
I am building an Epi Valve Junior using transformers from a Bogen AP-35. I have a mystery output transformer and i'm hoping someone might have the wire color connections. The OPT is marked 83-336-000 and -606-4-46 below that. The primary has blue, brown, and red wires; the secondary has black, yellow, and green wires. I believe the AP-35 is a push-pull, so my guesses for the colors are:
blue/brown = plate
red = B+ (center tap)
black = ground/ bottom of OPT sec. winding
yellow = 16 OHM tap
green = 8 OHM tap
But these are only guesses and i'm hoping someone can verify or correct me.
Thanks,
Marcus
youngpedals is offline   Reply With Quote
Old 01-17-2009, 02:51 PM   #2
It looks like you're close. I'm looking at the schematic for a MX30A and the red is B+, blue and brown are the plates. Black is Gnd./com, yellow is 8ohm and green is 16ohm. hope this helps.
olive2sing is offline   Reply With Quote
tweed output transformer abro163 Tweed Builders 7 09-11-2008 04:53 PM
Output transformer for both SE and PP Paul P Theory & Design 2 01-07-2008 11:29 PM
DIY Output Transformer thomasdj Build Your Amp 2 12-08-2007 03:41 PM
Check out my new output transformer. Steve Conner Lobby 19 06-30-2007 07:08 PM
PP 2.5k primary Output Transformer walkman Theory & Design 8 06-17-2007 07:48 PM
