Old 01-11-2009, 10:36 PM   #1
Need some help with a Peavey Delta Blues.
I started working on this amp because of loud snap crackle pops. haha Anyway I got that taken care of. Ended up being a resistor and a cap. Now when the amp is powered off however it make the loud squeal or chirp. I am real careful with amps and made sure not to damage any of those crappy wires connecting boards. I check and rechecked to make sure it wasn't something I did and looked over and over again at all solder joints. Didn't do it in the beginning but now is. Could it be a coupling cap?
StratTone is offline   Reply With Quote
Old 01-11-2009, 10:43 PM   #2
Does it squeal with the reverb all the way down? Sometimes op-amps will squeal as their power supplies collapse.
More likely something else, though.
Don Moose is offline   Reply With Quote
Old 01-12-2009, 05:55 AM   #3
Boy is that crap on my face. No squeal at all. What a crappy design. Will a TL072 do the job any better. Might have the part number wrong but I think that is it. These things really do need a standby switch.
Old 01-13-2009, 01:41 AM   #4
STandby switch is a waste of parts and labor on an amp this small. If all you want it for is to miss out on a power down noise, then turn the reverb pot down. Lots of amps make noises when power turns off.
Changing the 4558 to a TL072 is no more likely to change things than simply installing a different 4558. I don;t see an excess number of failures with this design, seems to work OK in my experience. Now and then you have to replace one, but I replace a ton more reverb pans than drive ICs. I think replacing the reverb pan is THE most common repair I do to Fender Blues Juiors.
__________________
Old 01-13-2009, 01:41 AM   #5
Horses first, then zebras. It's usually something simple.
Any good, low-noise audio op-amp will work - most of the 8-pin duals have a common pinout. You could work though the selection guides on the National, Linear and TI websites, or see which of those your favorite supplier has for cheap.
Hope this helps!
Old 01-13-2009, 02:26 AM   #6
I have no idea on this, but since the op amp has to drive the reverb pan transducer, it is conceivable that some op amps might not be as happy driving that load as others. HAving said that though, I would myself stuff most any op amps I had into that socket if the need arose.
__________________
Peavey Delta Blues pchilson Maintenance, Troubleshooting & Repair 30 01-14-2009 04:44 AM
Peavey Delta Blues buzzing WholeToneMusic Maintenance, Troubleshooting & Repair 12 04-14-2008 09:17 PM
Peavey Delta Blues hum. please help! andrewmay Maintenance, Troubleshooting & Repair 5 07-16-2007 02:06 AM
Peavey Delta Blues pbdog Maintenance, Troubleshooting & Repair 1 05-24-2007 12:52 PM
peavey Delta Blues pbdog Maintenance, Troubleshooting & Repair 4 04-02-2007 07:37 AM
