| | #1 |
| Senior Member Join Date: Jun 2007
| Switching high voltage
I added a switch in my 5E3X2 to my B+ voltage reducer (from geofex mosfet follies). So this switch is a DPDT and will have these positions: Position 1 = the B+ is stock wired directly to the OT center tap. Position 2 = the amplified 50v zener will be in series with the center tap and B+ supply. The switch I'm using is rated at 20amps/125v. Can someone please educate me on how much current/voltage will be running through said switch? Also, is it safe to switch while the amp is on? Finally, would adding transient suppression diodes or caps across the switch help? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| isolation transformer - high voltage. | atmars | Maintenance, Troubleshooting & Repair | 3 | 07-16-2008 05:34 AM |
| Heater voltage too high! | thomasdj | Maintenance, Troubleshooting & Repair | 9 | 07-15-2008 09:08 PM |
| using 230v mains voltage directly for high voltage | black_labb | Theory & Design | 6 | 02-03-2008 06:41 AM |
| relationship between high voltage supply and plate voltage | studioit | Theory & Design | 10 | 06-06-2007 12:22 PM |
| high power supply voltage | Hubie | Debugging Your Build | 11 | 05-03-2007 11:30 PM |
